I finally got around to making a video that demonstrates the 4K-X cameras (2.8mm, 3.6mm, and 6mm). Just for the heck of it, I also included the Color 4K T180 at the end. One of the things I have found difficult when setting up cameras is guessing which camera will work best at a specific position or for a specific purpose. Since there are still lots of questions about the Color 4K cameras on this forum, I thought this video might help. I uploaded it just now to YouTube in 4K resolution, so hope it looks ok.
For my setup, I mounted each camera at the same position at the front of my property next to the street. I did this on different days, so they would be exactly the same. I even used the same camera settings for each of the three Color 4K-X cameras. Day: Manual 0-2 shutter, 0-35 gain, Adv 3d = 26, Adv 2d - 26, WDR = 24, WB = outdoor Night: Manual 0-8 shutter, 0-40 gain, Exp Comp = 36, Adv 3d = 51, Adv 2d = 39, WB Red=13 Blue=42 Illuminator=off H264H @ 15fps and 10,000 bit rate
I used the power pole in the image as a focal point. Note that half-way across the street is 26 feet from the camera, the power pole is 54 feet away, and across the street to the neighbor's house is 94 feet. Nothing exciting happened on the three days I swapped out the cameras, but I tried to get some videos of automobiles and people out walking to give an idea of the resolution--especially concerning the 6mm camera, which doesn't get many favorable reviews on here; but I like how it works. That is why I included the man walking his dog about 58 feet away and then again about 5 feet from the camera when he crossed the street and passed by in the opposite direction. Even up close, the image isn't that bad.
I'll attach a diagram of the layout, so you can see how it was set up. One other note is that each of the three Color 4K-X cameras has the latest firmware from Andy (3_V2.840.0000000.25.R.230425) and also the Color 4K T180 (3_V3.120.0000000.21.R.230418).
YouTube Link:
Appreciate the work you put into this demonstration, very useful indeed. I have a couple of the 4K-T cameras which are superb, looking to install another which is approximately 15-17 feet to target. From you samples it seems like the 3.6mm which I was considering has quite a narrow focus window, almost looks like beyond 15-20 feet is going out of focus. Where as the 2.8mm seems sharper to me for path which is closest and also the road, then properties behind also. The 6mm looks great on the silver car when turning but that I guess is around 35-38 feet range based on your street view map, the 6mm is not an option for shorter distances one would assume. I am now totally confused and tempted to go with 2.8mm since my focus range is between 15 and 20 feet max estimated. I am looking at the 4K-X models rather than the 4K-T for this particular location, so identical models to your test scenario.
... I really need to look at the spec sheets closer. Regardless, image quality wins over all else for me and that is apparent by the bucket load. It is taking me a while to adjust to colour images at night, so used to IR for the last 10+ years, being able to ID color of clothing or vehicles though should be a big advantage.
