SMD 3.0 dahua
Yep prompted for the new plugin
Nope Firefox, nor Pale Moon nor IE can get a stream
SmartPSS is still pulling the stream (old version)
Plug-in fails
Maybe try option 4 I listed if blowing away the webrec folder and see if that assists. Also remember the rtsp stream option should you need it although like you said you at least have SmartPSS for now.
@bigredfish
See if it’s related to Windows 10 real-time antivirus causing the integrity failure. Try turning it off using below
Turn real-time protection off temporarily
  1. Select Start > Settings > Update & Security > Windows Security and then Virus & threat protection > Manage settings. (In previous versions of Windows 10, select Virus & threat protection > Virus & threat protection settings.)
    Open Windows Security settings
  2. Switch the Real-time protection setting to Off and choose Yes to verify.
Interestingly, could not do it from the NVR 4116-8P. I had to take it off the NVR and reassign to my 192.168.1.x network and then do it from the Config Tool.
IVS Intrusion is not detection Humans with SMD 3.0 firmware. The camera on the right has the SMD 3.0 firmware and the camera on the left has the old firmware. I just changed the camera on the right to tripwire to see if it does the same and not detection Humans, I will update my results in a day or two.
View attachment 2021.04.17-12.04.mp4
I tested IVS tripwire also did not detection Humans. Not until I rebooted the camera then both IVS tripwire and Intrusion started working.
Why does the IR wash out when you approach the camera in SMD 3.0?
All, as promised last night, here is a quick clip showing the difference between SMD 3.0 vs SMD 2.0 with regards to IR (Auto vs Smart) on a 5442 Vari Turret. Make sure to select minimum of HD although I did upload native res which will be available when YT finishes processing as 2K.
Thanks for confirming that, much appreciated :)
Because this firmware lost Smart IR, so they are looking at adding it back.
With 'Auto' only this causes issues with washout as its not as effective as 'SmartIR' algorithms BUT its not only that SmartIR adjusts better (which it does) in this case. In SMD 3.0 you barely see the IR adjust for a target, period (confirmed with further testing). This is also noticeable in code comparison between old (improved 2.0 versions) and new. As @EMPIRETECANDY said, Dahua aware and working so hopefully new FW to test in May even if its SmartIR re-added first and then the addition of the AI improvements to counter for the animals as humans issue
HTH
5442 Smart IR 3.0 Beta firmware will be released very soon, 2-3 hours Can be ready to send out for doing some testing
great! Would be nice not to get awaken by stray cat alerts at 3am :) I hope this pans out.
Reactions: sebastiantombs
