Smartpss lite window size?
exarkun
Jun 14, 2019
45
12
Florida
Can you resize the window for the smartpss lite application in windows? I can only maximize and restore the window. Am I missing some option/setting to enable this?
Yes just like any other program? I just did
Weird, when i hover my mouse near the edges of the program windows or on the corners I do not get any resize arrows...
which version are yourunning? I'm at 1.003.0000004.4 from 24 October 2023
You're using smarpss LITE (not the non-lite version) right?
Reactions: JDreaming
yes Lite. (I have both)
Hmmm You’re right no arrows. Mine goes to about 1/2 screen by clicking the restore button when fully open
Just installed PSS Lite. Has anyone found a fix for resizing the window? I need to make it bigger without going full screen. Otherwise i will stick with the old SmartPSS.
press alt+ specebar, then select size and then with the arrows of the keyboard you can make it smaller or bigger. After resize close the app by clicking in the x, that will save the possition. note that if you minimize or full screen you will loose the size again. (windows 11). i have tried this software and it worked fine, you just program the resolution to a short cut and it sizes with a click. Sizer 4.0 by Brian Apps. has to be a way to do it on the registry..... if i find a way i will post it here.
Worked, thanks. Hopefully it will stay the size I made it.
It stayed the new size for me. Try saving the layout with a new name once resized.
I could resize the window using the Atl-space. But it would not stay when re-opened. In fact, I could not get any of my settings to re-open after I saved them. It kept opening to the default settings.
