mlapaglia
Getting comfortable
- Apr 6, 2016
- 860
- 513
Hi, Thanks for the info Mat. I've already begun scanning the info you sent and I'll continue to keep reading up. I think my priority is the front door, second prority would be driveway if possible. I'm thinking something like this? Depending on where I actually mount it and where the door is compared to the roof I may cut off a little more of the driveway but I think that's OK.
AnglePlan by philipgonzales3, on Flickr
Will I need to buy a junction box? It's a rental house and I don't want to make any large holes. My plan was to run the Ethernet cable out an existing hole that is used for coaxial cable. Then just plug the ethernet into the camera. So basically just make the small holes only for mounting the camera. I was reading something that said either drill a big hole for the cable or buy a junction box? Does that sound right?
Regards,
Philip
Are you wanting to identify people with it? A camera with that wide an angle is going to suck at night making someone's face out. If you're worried about your front door, find a place to mount the camera beside your door pointed where people approach from and get a small FoV, try 6 or 10.
AnglePlan
20170918_215213 (1)
20170918_214351 (1)
