Ok - I removed both and tested it in BI, but no dice. It triggered an alert image, and when I used the script in the cmd prompt, it did send the image. Here is the script with your edits: -s --form-string "token=XXXXX" --form-string "user=XXXXXX" --form-string "message=<b>&CAM</b> &MEMO <a href='&WAN/alerts/&ALERT_DB?fulljpeg'>Hi-Res</a> <a href='&WAN/ui3.htm?rec=&ALERT_DB'>UI3</a>" --form-string "html=1" -F "attachment=@c:\BlueIris\Alerts\&ALERT_PATH"
I tried using the alert with msg.exe. When I use the basic script, I do get the message when I hit "test" - see the picture. But when I put the pushover script after it, nothing pops up, either when I hit "test" or trigger the camera from outside. I even tried inserting a specific, existing .jpg file in place of &ALERT_PATH, but again no message.
