tangent
- May 12, 2016
- 4,641
- 3,997
Seal where the cable goes through the building wrap behind the siding and route the cable to you create a drip loop. Some siding mounting blocks have a built in junction box that would give you some space for the connection. Also seal where it goes through the siding / siding block.So I got lots of good information, but still wondering exactly how to seal up the holes in vinyl siding/house sheathing.
Can any anyone give a rundown on exactly how one of these vinyl siding mounting blocks will be installed?
Builders Edge 6.625 in. x 6.625 #001 White Triple 3-Surface Universal Mounting Block-130110007001 - The Home Depot
Also, using the Dahua PFA137 mounts on top of those blocks. I'm looking to find out exactly what is sealed where, and what hardware should be used to attach to the house. Thanks!
I still think I'd put a camera for LPR up in your soffit. The Z12 and Z5 cameras aren't tiny and down low might look a bit obnoxious
