- Jan 30, 2017
- 835
- 320
Is it gonna get rained on? I'd think silicone around where the wires go in would be fine, I'd it's under an eve I don't think you need to do anything.Any creative ideas for the Bosch non waterproof pir's outside? Was thinking of making a little roof like mount to keep them dry. Maybe a little silicone to keep them dry.
Check out Altronix which has many configurations and sizes.I will search for 12v regulated. Just making sure I'm on the right track.
I wouldn't use that power supply it's way more than you need, to the point of being dangerous for this use. 2 PIRs and a powered microphone are going to consume < 0.3amps. Also 1.8v over voltage could be problematic.Would something like this be sufficient to run the mic and 2 pir's? I could then bypass the splitter and if the part goes bad would be in my laundry room computer area to swap out. Running a little wire will be cake work since the cat 6 cable is there.
TekPower TP1863 12 Amp DC 13.8V Regulated Power Supply with Fuse Protection | eBay
I wasn't set on that model. Just an idea of a wiring solution. I am planning on using the supplied power supply that came with the SD59 ptz. Being the camera will be on the corner, the pir's don't have to be that far hopefully to get the coverage I seek. My house isn't that large in the first place. I will stick with the PoE splitter for the microphone. That leaves getting power to 2 pir's.I wouldn't use that power supply it's way more than you need, to the point of being dangerous for this use. 2 PIRs and a powered microphone are going to consume < 0.3amps. Also 1.8v over voltage could be problematic.
I was suggesting some small 24VAC to 12VDC power supplies because I thought you said you were using the 24VAC power adapter that came with the PTZ. This makes it easy to power a few other things, the supplied 24VAC wall wart has plenty of headroom. Then you just run your wires for the motion detectors to the PTZ, connect the alarm inputs and install and connect the 24vac to 12vdc power supply.
As for using indoor motion sensors outside:
Sun, water, and spiders all have potential to cause problems.
Create a drip loop with the wire so water will drip off and not run into the detector, then caulk it well.
Protect it from sun/rain/snow as much as you can, I would try it under the eaves (don't staple the wire yet / or run the wire in the attic yet) because that's probably your best option. Test it and decide if the eaves will work or not, don't write that location off outright
It's honestly simpler to leave a PoE splitter out of it. Just get something like this: Amazon.com: 24VAC To 12VDC Convertor For CCTV Security Camera Power Supply Adaptor: Home Audio & TheaterI wasn't set on that model. Just an idea of a wiring solution. I am planning on using the supplied power supply that came with the SD59 ptz. Being the camera will be on the corner, the pir's don't have to be that far hopefully to get the coverage I seek. My house isn't that large in the first place. I will stick with the PoE splitter for the microphone. That leaves getting power to 2 pir's.
Yes, but you'd run the 24VAC not the 12VDC into the ptz. It would all be powered off of the 24VAC wallwart inside your house.So I would run the cameras 24v ac adapter to this adapter. I'd then run the camera, mic, and 2 pir's off of 1 adapter? Forgive me for my lack of knowledge. I'm learning slowly.
I don't use blue iris so there's a limit to how helpful I can be on that front. There are some settings in blue iris related to using "DIO" or motion detection on camera in blue iris. This thread is about an indoor hikvision cube camera with a built in pir, but you get the idea: Hikvision DS-2CD2432F-IW PIR SettingsThanks for all the help tangent. All worked and works. Some reason no triggers being reported on my time line. Ordered a Sealevel 120poe. Will post up when I get her up and running good.
