NoloC
Getting comfortable
- Nov 24, 2014
- 685
- 461
White face was v1. Should work poe but a lot had problems and running with a power supply or a splitter proved better option.
So since you plugged it in and nothing happened, we have a few options:
The cat5 cable is bad. (try another cable)
The port was not a poe port or bad. (verify poe port and try another port)
The camera is not responding to poe. (power off 12vdc supply and see what happens)
When the camera initially starts (power first applied) it will drive the ptz motors to find the limits. That would be the first step before trying to locate on the network.
