Reviving Amcrest IPM-721S - steps?
Diver4242
Joined
Jun 19, 2014
Messages
14
Reaction score
I just found an Amcrest IPM 721S that I used to use some years ago. I'd like to revive and use it. I downloaded the latest firmware, manuals, software for the camera. I think I used to use Blue Iris. Is there a better choice between the Amcrest software/app and Blue Iris? Do both or either one charge? I want to avoid subscriptions and just record to microSD and get alerted if there's activity (outdoor monitoring of our RV).
What steps should I take? Use the Amcrest config app to do the firmware upgrade, then move to blue iris or the amcrest app?
Thanks in advance for any help.
TonyR
Joined
Jul 15, 2014
Messages
17,470
Reaction score
40,689
Location
Alabama
Use a PC to perform the F/W upgrade, do via Ethernet not wireless.
Blue Iris ("BI") has a 15 day trial, costs $63 one-time beyond that, updates & support included for first year.
The Amcrest app for PC and phone is free but BI can run circles around it.
The BI app for phone is OK but not required, use BI's built-in webserver "UI3" to view cams using a browser.
EDIT 11/23/23 @ 1613 CT: Apparently you were using BI back in Aug. 2016: :cool:
Top
