- Jan 28, 2018
- 1,656
- 1,196
Hello Catcamstar,
Is the VTH able to show the feeds of dahua cameras that are connected to the network switch (considering connecting the VTNS to the network switch as you suggested) ? (I planned to use blue iris and not an NVR on my installation)
Thanks!
Ciao @Xavier6 - yes, as long as the VTH can "speak" with the camera's (eg if you setup your BI pc with dual NIC, the VTH is assumed to be on the 2nd NIC together with the cams & VTO). it should work. If you don't manage to get the video feed to show up, you may have to verify:
- VTH connects to non FullHD stream (eg D1 substream)
- substream feed has no 50fps
- account has "enough" privileges (first try with your cam's "admin" user, then limit it down with "read-only" user until VTH refuses to show stuff).
Good luck & happy camming!
CC
