Review : TPC-BF1241 Dahua Thermal Bullet Camera
Update on visible camera video quality.
It seems that on some of the previously posted videos, the visible camera quality was lacking. I looks like it was using the sub-stream video when I was recording the side by side videos. The screen capture program used to record the video may of also reduced the quality a little bit. Here is a clip using the main stream. Watch the squirrel in the upper left corner. The resolution gets better at about the 11 second mark on the first clip.
Here is a clip directly from BI.
In BI, I have the visible and thermal in a group, the clips show up side by side. Is there a way in BI to export clips showing two camera views side by side at the same time? The only way I can do it now is to use a screen capture program.
