1. What do you mean saying hack TELNET?Did anyone find a way to “hack” into the cam by
Try to install latest beta firmware. I've been told that XM is fixing ssl email issues last few months and there are new firwares with working gmail, at least for their DVRs.to somehow enable the HTTPS and SSL SMPT email account access
9527 - Sofia telnet-based debug consoleWhat is exactly the purpose of these open ports: ??SOFIA?: 9527, ??: 8899, ??: 34567.So far I use mainly HTTP 80, RTSP 554, TELNET 23
There was a link to old firmware with working wifi a couple of pages before.Is there anywhere I can get a new firmware?
I have checked the camera. It works fine but the wifi option has disappeared hence the reason I can't connect. Looks like the update I installed has removed it. Is there anywhere I can get a new firmware?
I have obtained firmware for my camera now and all is ok including wifi.
Have replied to your pmDid you use my software ?? and also wpa/wpa2 ??
Check camera RTSP stream with VLC media player or/and ONVIF manager. If it drops the same way in case your camera dosen't equpped with wifi i'd recommend to update to the latest firmware.RTSP stream seems to drop consistently every minute or two
Using Putty client, connect to your camera port 9527 with administrator login/pass (default: admin/[no password]). More details on telnetting camera: http://www.hkvstar.com/technology-news/china-ip-camera-configuration-firmware.html chapter:"6# How to access IP cameras via Telnet?"Are there any log files or connection information commands available to the camera that can be monitored for troubleshooting connection drops, etc. by telnet?
If i understand you correctly you are trying to use same addressing on both LAN and WLAN adapters. Unfortunately, this won't work. You have to put different subnets for LAN (192.168.3.27) and WiFi (192.168.2.27), for instance.As soon if i disconnect my lan cable no ip is found on my network.
If it is wireless you must see the 192.168.2.27 i think.
Then type 'help' to see all available commands. Anyway, if there are some errors or debug messages, they will be printed on the screen without any user input.
thanks.
I think I can rule out the problem being with GV-NVR because the same dropouts happen with ONVIF manager as well.
When I telnet in, I see this message:
>>>>CAuthDevice, <ERROR>:Timeout!!! Wait for PEER_REGISTER_RSP !!!ip[54.84.132.236], port[9000]
I think that ip address belongs to an Amazon.com cloud server but I'm not 100% certain.
Is this Timeout error normal?
I don't have a gateway set on purpose for the camera. Curious why the camera wants to connect to that location unless it's just to use the built in cloud service for storage, etc.
When I run the ver command from telnet I get this info, is this the best firmware for me to be using?
admin$ ver
ver ---- V4.02.R12.00006510, [000 06 510]
Version: V4.02.R12.00006510.10010.140700, BuildTime: 2015-09-10 10:20:36
If I monitor it with ODM the connection drops and I get no signal displayed.
On VLC, it seems to keep going.
The debug output on the "Sofia" port is buffered, so you need to hit return or whatever to bring it in to sync after the connection drops.
2. Didn't hear about it. I would love to have source code of it to make some mods.
3. They supposed to be edited, zipped and upped back to device. What is your problem?
4. Type in telnet: strings /path/to/Sofia | grep 'something'
6. Didn't hear about it too.
Beta stuff: https://translate.googleusercontent...1.html&usg=ALkJrhhnCZGxa-d4T-jz7BvlT6-vKo0UBw
Don't install anything from there in case you've got working wifi in your cam!. You've been warned.
8899 - ONVIF
34567 - Main Sofia port: authorization, CMS, proprietary video streaming.
