@Arjun
I wanted to take some time with this reply as to be fair this is an apples to oranges comparison due to focal length, optics, sensor, SOC, ram differences etc.
So, with that said, I would have to caveat that as LPR requires a nice tight image to ensure successful capture (and that in most installs you will have an overwatch cam for wider details of the same area), that for this comparison we must assume the image view is identical (same distance, height, angle to target which really are critical) and achieved by mounting the cams in 2 different places to accomplish that.  I will also assume that Z4 and Z12 have been set to attain the same proportion of vehicle details within their respective FOV. For me personally I look to have the image on the LPR tight enough (in some situations) to where the vehicle is at least 30,40,50% of the image. This is even more critical if you cannot control or install in an area with a choke point.
If that’s the case then the 4MP (B5442) takes the edge for detail primarily due to pixel density and sensor performance.
However the 5241 and 5231 are absolutely viable, no slouches and gain IR distance over the x442 and therefore allow for more IR on target at night in that same situation. This can be a necessity depending on the lighting within a given capture zone. That’s not to say either would fail at its task (far from it) BUT the 5231 followed by 5241 would allow for a little extra IR if needed. In some situations I’ve had to run the 5231 / 5241s at close to full zoom (greater than 90%) and therefore that extra IR distance has been critical.
The 5231 is a rock solid powerhouse in the Z12 with 2 known issues (
1, softer focus beyond 80% zoom and
2, tendency to shift focus), even with those it still performs solid LPR for me. The 5241 (that replaces it) does not have these issues BUT is a more ‘processed’ image (can add noise) so as long as you cater for that when dialing in the shot, you’ll get an elevated image over the 5231.
Now, lets tackle AI as that is a feature of the 5241 and the B5442 (both Pro AI) but NOT the 5231. Lets be honest, in any situation where you need to review captures, you want to have a slick workflow. Reviewing hours of footage is painful and costly (I know a number of us have done this over the years). That is where AI steps in. Thats not to say its perfect yet OR that there won’t be situations where you do have to manually review BUT it does (with vehicle filtering enabled) allow you to know that the capture you are looking at has a 90%+ chance of being a vehicle which, if configured as an LPR cam means, opportunity for a plate.
So in summary, all 3 cams (including the 5231 still) are amazing for this type of work. It all comes down to install location and your ability to dial the shot in for the required end results, plate captures. As myself,
@bigredfish  and others have stated for some time, LPR captures are an art form, get it right, you’ll be amazed at how well these cams detect, get it wrong and you’ll be dialing in shots night after night. Hopefully, in the posts we’ve all shared in the LPR forum, we tackle those settings / situations to help others get there quicker.
The Z12 variants afford you a flexibility in shot that the Z4’s come closer to for sure but in some situations you still need more distance or just want a tighter image, in which case the 5241 has your back. If you can get a tight image through install location allowing distance to target to be optimal for the Z4’s then absolutely go that way as you won’t be disappointed with the night performance of the 1/1.8” 4MP sensor. For the price of the B5442-Z4 you really get a lot for the money.
If you want my advice on an upgrade pick (and your budget allows it) then I would recommend the 7442-Z4 as that really takes this up another notch giving you plate and vehicle metadata which again assist greatly in search and review situations especially with an AI NVR in the mix. Hopefully the Pro AI & Ultra AI series may see a Z12 variant, which if they did, I know I would be buying a number of those units
 This may not be possible due to the current lens to sensor pairing options and Dahua’s focus BUT I know Andy (
@EMPIRETECANDY) is feeding back the requests, THANK YOU ANDY !
In the mean time, the B5442-Z4, 7442-Z4, 5231-Z12 (no longer available), 5241-Z12 offer amazing options for LPR (day & night)
BUT again remember it all comes down to distance, height, angle to target and can be elevated further using choke points, overwatch cams and carefully dialing in your shot.
Apologies to all for the long post, hope this helps you and others.
Quick cam details for those mentioned in this reply for reference:
5231-Z12
1/2.8”
5.3mm to 64mm
F1.4
0.006 @ f1.4
IR to 656’
256 Ram / 32 Rom
5241-Z12
1/2.8”
5.3mm to 64mm
F1.5
0.002 @ f1.5
IR to 492’
512 Ram / 128 Rom
B5442-Z4
1/1.8”
8mm to 32mm
F1.6
0.002 @ f1.6
IR to 394’
1GB Ram / 128MB Rom
7442-Z4
1/1.8”
8mm to 32mm
F1.6
0.001 @ f1.6
IR to 393’
4GB Ram / 2GB Rom
			How does the  IPC-B5442E-Z4E (range up 32mm) compare with the 5241-Z12 (range up to 60mm, mostly used for LPR).  I know the Z4E has the better sensor, but for nighttime, in your opinion, what would you opt for?
