biggen
- May 6, 2018
- 2,956
- 3,393
I have exposure compensation turned down to about 15 and the IR illuminators turned down to 50 if that helps you play with the settings a bit.Ah, there it is. I'll play with that. Thanks.
Ahhhh.... GotchyaYou'll have to use the "Schedule" profile.
The Day/Night profile uses the camera's built-in light sensor to decide when to switch from color to B&W. I dont think you can override it.
Using google chrome to view the cam directly via IP. All devices hardwired to switch. Viewing directly on the local networkWhat are you using to view? The NVR GUI Live interface or SmartPSS? and are you viewing over Wifi or direct cabled connection to the network, or remote??
Hard to say where the bottleneck is, could be either.. I see similar messages from time to time that usually sort themselves out if I have a good strong connection, so most of the time I'd say its your connection
Login your camera settings using Chrome, go to Conditions--> Profile Management, set it to "Full time", and change the option to "Day".OK - So silly question time - How do I force Night profile to be in colour?
In Profile Management, I have it set to Day/Night
The Day & Night option becomes greyed out
However at night I have 1 street light which must provide enough light to keep it in day profile, but i would like it to go to night profile so I can make some minor adjustments
As soon as I change the profile to night it goes to B&W
This is a still from night, but in Day profile
Thanks
Try turning "Smart Codec" off. It may create some trouble from my experience.Ahhhh.... Gotchya
Thanks
Now 1 more question.
I have been trialing different main stream settings and when I have high resolution and bitrate settings, i keep getting the yellow warning on live view "it is recommended to enable substream for better video playing experience"
Does this mean it more of my pc cant handle this setting to view, or my actual Local network (router/switch/cabling)?
Im in the process of upgrading my pc anyway, but would be good t know if i need to look at the rest of network equipment
Then same under Conditions, go to Day&Night, choose "Day", and change the mode to "color".
Sunrise/Sunset requires Full Time, not Day or Night, right? That is what I'm using. Than select Conditions, Day & Night, select Color, and works great for me.
