Review-OEM 4mp AI Cam IPC-T5442TM-AS Starlight+
Is there a particular model that you chose? I see several 5442 bullets.
Also, why do you prefer bullet over turret?
thanks!
Maybe I can answer, he likes spiders to keep the bugs away for night IR :)
Reactions: djernie
What is the correct wall mount bracket for this cam (without junction box)? The usual pfb203w doesn't work, holes don't align.
Digging my way through 50 pages but I'll just ask before I am done: Did Dahua ever solve the overexposure and IR at night time on IPC-T5442TM-AS? As it makes close rage recognition impossible.
Was SmartIR ever added to firmware?
Update:
After a new firmware update, the IR issue is solved.
Firmware has yet to be officially released.
The AI and IVS features are now working properly again as well on this cam.
Nice! It was fixed.
Nice! It was fixed.
Dahua hasn't released a fixed firmware yet. We are all still waiting.
You can check out this post: IPC-HDW5442T-ZE New cam from Dahua :)
Dahua is moving to the same firmware for all the 5442s.
I have two 5442s. Smart IR does not work in its current state. You have to use manual and tone it down. Hopefully Andy will release the newest firmware that corrects it soon.
Thank you. I saw the video Andy posted just under the post you linked. Looked pretty decent to me but I guess this is an ongoing struggle to improve and fix firmware ever so slightly. I think he said he'll be using this one with all new stock from now on.
Yeah its not really that big of deal to be honest. Its easy enough to manually tweak the settings and turn down IR just a bit to avoid the washout. But it will be nice to have it fixed going forward as well.
Yep, I think I'll still buy this one as my base camera. Btw, did we ever get a varifocal turret 1/1.8'' 4MP option? I am on page 21 so far and it seems keeping the camera fixed in place is a bigger issue than IR at this point.
IPC-HDW5442T-ZE New cam from Dahua :) Varifocal Thread
Question, so the post from Widlcat_1 does it apply to the fixed 5442 as well or just the varifocal?
As far as the "tweaks"? I don't know but I'd say its a good jumping off point. I have the fixed version and did my own tweaks and tinkering to avoid the washout before he posted his review.
Thank You. Would you mind sharing yours? I will be setting up my 5442 fixed soon and will want to tweak it until the firmware fix comes available.
Thanks,
David
