Good catch, deleted post.On dahua website, for the IPC-HDW5442TM-AS, the firmware is the DH_IPC-HX5XXX-Volt_MultiLang_PN_Stream3_V2.800.0000000.12.R.200319 ... shouldn't be DH_IPC-HX4XXX-Volt..... ?
It's the 2.8mm that is hard to get. I ordered two from Amazon and then later they were out of stock, so I ordered two more from AliExpress. The packaging from AliExpress was different, but the camera is the same, all came with the Nov 2019 firmware. I would like to get one more camera, but I was thinking about getting the 3.6mm... just wish I could see the difference first in the lens. The 2.8mm lens seem to have a curvature to the image and 3.6mm may have less or none.
I've been running the 5442 using both BI motion detection and IVS, ONVIF triggers. I'm plagued with false triggers due to shadows with both, especially in the morning. The camera looks west and there's a big spruce just east of it that waves, so nicely, in a gentle breeze. So, yesterday I switched it to facial recognition since it really covers the approach to the front door area. That got rid of the false triggers but last night it didn't work out so well.
When in facial recognition mode control of the image, gain, compensation and so on, all can't be adjusted. I keep the camera in color mode 24/7 and without being able to control things color at night just doesn't work. The firmware is V2.800.0000000.11.R, Build Date 2019-12-30, which I think is the latest. Anyone else notice this? Is there a reason why normal "tuning" adjustments can't be made in facial recognition mode?
If you are getting a lot of false motion events due to moving shadows, you can try this trick...
Create three zones in BI.
Zone A is the entire field of view
Zone B is the edges of the camera's field of view - not too big however because you don't want to create a zone where someone can walk around the edge and not trigger the motion
Zone C is the part inside of zone B. Because you have zone A, you don't have to worry about touching zone B with C, but the two should be close, but not overlapping.
Then create your motion trigger when B>C. This will catch anyone coming into the frame, but will get rid of most false triggers due to shadows. At least this has worked well on my cameras that tend to have a lot of shadow movement.
You don't have to use these zones all the time either. You can create profiles based on the time of day and change the triggers for each profile. So use this profile in the morning when the shadows are bad, and go back to a more normal zone/trigger set up for night and afternoon when the shadows aren't bad.
Been there, done that. Problem is the amount of shadow and how it progresses and otherwise moves with the wind.
I’ve also tried doing this but for me BI would then miss some events. So for example when we weren’t all locked in my kids leave for work at the same time every day and randomly it would not record one of them leaving or arriving back home.
Hi there, is the 2.8mm better than the 3.6?It's the 2.8mm that is hard to get. I ordered two from Amazon and then later they were out of stock, so I ordered two more from AliExpress. The packaging from AliExpress was different, but the camera is the same, all came with the Nov 2019 firmware. I would like to get one more camera, but I was thinking about getting the 3.6mm... just wish I could see the difference first in the lens. The 2.8mm lens seem to have a curvature to the image and 3.6mm may have less or none.
Great, and can i recognize people better with 2.8 or 3.6?You will have a wider view.
The wider the view, the closer someone has to be to be ID'd. So the 2.8 would need someone closer that the 3.6mm for an ID of the face.Great, and can i recognize people better with 2.8 or 3.6?
| Lens | Detect | Observe | Recognize | Identify | |
| 2.8mm | 58m(190ft) | 23m(75ft) | 12m(39ft) | 6m(20ft) | |
| 3.6mm | 72m(236ft) | 29m(95ft) | 14m(46ft) | 7m(23ft) | |
| 6.0mm | 113m(371ft) | 45m(148ft) | 23m(75ft) | 11m(36ft) |
