Review- New Design Tendelux 10 Watt IR illuminator.
This nearly identical model at HD has the same number of LEDs, a narrower field of illumination, and yet 1/4 the effective distance (which is probably the more accurate number). The reviews for both models are also terrible. While I am in the market for a new illuminator, I think I'll be passing on these models.
I can confirm, that at least for license plate purposes, the Iluminar IRC99-A60-24 IR illuminator is top notch when compared against Tendelux. The Iluminar IRC99-A60-24 IR illuminator has a more concentrated IR output. Parley has found an excellent product. :cool:
Have you tried out the Tendelux DI20 20 Watt IR illuminator? It's a 90* beam but claims an effective range of 150-240 feet. I have a z12e set up as an lpr at about 130 feet with a DI20 aimed in that direction to help out. The Iluminar claims a range of ~100 feet but the beam is a little more focused. It's also 2x the cost of the DI20 and 15 watts. I have a second z12e facing the other way I thought about adding extra ir to. I may try out the Iluminar is the extra money equates to much better performance.
I have found the Tendelux to be useless for LPR. I could not see a difference with or without it on my LPR camera.
Further on my cams with 1/60 or 1/120s shutters, I do not see an effective range in the 150-240 feet range. More like 70ish.
Now with an auto shutter (that obviously is slowed down a lot), yeah it is bright out to 250 feet, but we aren't using auto shutters in these applications.
My Illuminar reaches out further than the specifications say. 100' is quite conservative for the 60 degree version.
I guess I need to unplug it to see if the captures are much different. I installed it at the same time as the camera but I don't recall testing the camera without the ir.
That's good to hear. Most of the times, the numbers seem to be only in best case conditions. B&H says expected availability is in 3-7 business days so it wouldn't be that long of a wait. These cameras are becoming more expensive than my jeep.
Reactions: StevenFromTexas
I have found that the availability is about twice that time unless they have restocked a bunch of them. Mine was shipped from Southern California. I have found the wait time to be well worth it.
Yes, I had been using the black Tendelux DI20 IR Illuminator for each license plate camera and just threw both of them away! They are on their way to the City of Lubbock dump site. I still have a third one in case I want to use it for comparison purposes. Another good thing about the Iluminar IRC99-A60-24 is that it has a metal body and looks more imposing than Tendelux.
I must agree with Parley again! :)
I'm glad it's metal. It looks kinda plasticky in the pictures. I went ahead and ordered it.
Thanks...I've got some jack connector pigtails and solder seals in my "holiday lighting synced to music" hobby.
Good! Contrary to my last post, it may be the male connector that is needed instead. But you're ready regardless.
Well, I purchased and installed a third Iluminar IRC99-A60-24 IR Illuminator. So I've got two of those in use on one license plate capture camera, and the third one in use with a Speco Technologies IR60 IR Illuminator on the other license plate capture camera. The Iluminar IRC99-A60-24 IR Illuminator absolutely runs circles around the Tendelux models for license plate illumination purposes.
My Tendelux DI20 IR Illuminator died after only 2 months. I thought it might have been the power supply, but it wasn't that. I'll inspect the unit at the mounting site tomorrow, but since I used high quality dual walled heat shrink tubing when I installed the connector at the unit, I'm 99.99999% sure it's not water infiltration into the connection causing the issue. I can't recommend it at all, though the performance was decent for the money given my low expectations initally.
Bottom line, is that I do not recommend it at all. I ordered a unit from Univivi per the above good reviews. We'll see how this one holds up.
Is the wall wart exposed to rain or is it protected?
