Robert G.
Getting comfortable
Just a couple of my own thoughts over using these cameras vs. using an OpenALPR based system.
PROS
Local processing - you do not require an additional computer sitting there consuming power on an OpenALPR machine. Running a computer powerful enough to process ALPR 24/7 is not cheap on the electric bill every month.
Cost savings - while it is more expensive to purchase the ITC237-PW6M-IRLZF1050-B initially, if you are not paying a monthly fee to OpenALPR you will be saving money after a couple of years of use. The additional camera cost is paid for in about 4 months if you are using OpenALPR commercial editions.
Some Vehicle ID - The ITC237-PW6M-IRLZF1050-B can attempt to do vehicle make/color detection, it is not particularly accurate but it is included. You get none of that info from OpenALPR unless you use their commercial plans.
CONS
Size - these suckers are much larger than HFW5241E-Z12E which most people on this forum currently use for OpenALPR
Cameras are Independent - if you have a pair of cameras (up the street & down the street for example) OpenALPR has the ability to use data from both cameras (front an rear plate capture for example) for more accurate plate reads. Would be super cool if the cameras could share data between themselves, but that is not likely to happen.
That's all I can think of at the moment. I will be running both these cameras & OpenALPR shortly, will be interesting to see which performs better.
PROS
CONS
