Shockwave199
Also thinking out loud, you might just try and give your preset 2 an allotted time. It may be that idle isn't initiating because it always thinks it's working on preset 2 motion call.
I found a workaround back a little ways.Also thinking out loud, you might just try and give your preset 2 an allotted time. It may be that idle isn't initiating because it always thinks it's working on preset 2 motion call.
Agree. Time task, not idle motion works the best.I found a workaround back a little ways.
I'll be the guinea pig for the new SD59225U-HNI PTZ.
so you've had no issues with the newest march firmware? was thinking about upgrading.
I've managed to get mine working pretty well both night and day using intrusion boxes
I still have 1 certain area that's hit and miss but it's on the very edge of the view which may be why.
What I have found is if you just use 1 big box over the entire area it doesn't really work well. But if you define certain spots within the view using intrusion boxes it works well.
You can pretty much cover everything you need within the fov by using smaller boxes in defined areas at clever points because there is only a few places an object can move in or out of scene if you think about it.
Also by lowering the sensitivity to 4 or 5 I find it works better. And tracks further
Ive still no idea what the track time and the 3 options do in the advanced tracking part
Tracking overlap rate
Track time
Track distance
as they seem to do nothing.
I've also found that the alarm track time effects the time it tracks more so than the advanced option
So what version of FW are you on?
I tried to upgrade to DH_SD-Eos_EngSpn_N_Stream3_V2.422.0000.8.R.20170315.bin twice now and after it boots back up it still shows the firmware from "2.420.0000.9.R.2512, Build Date: 2016-07-12" so not sure what the hell is up with that, it goes through the whole process, didn't try the PAL version, hoping I don't have to like, reset the camera.
I used that file and was able to update OK.
Also I see there is a newer PTZ firmware and I'm going to try it.
newer than 3/15/17? where?
Did you try setting the system default button prior to the upgrade attempt. Someone else mentioned that Dahua suggested this.
The newest PTZ version is 3.02.20 and on about page 5 or 6 on the FW site.
PTZ portion of the Firmware update went OK. So if anyone wants to update it's safe.
