nayr
you mean the set screws that attach to the arm? if anything loctite would be more than enough.. the mount needs some big lag bolts that its a good idea to pre-drill so you dont crack siding/lumber.
If it was on a mast then loctite everything or use locking nuts, stainless steel might even be a good investment, if not use galvanized/zinc coated at a minimum.
