Q™
A quick noob DIY question for this install. What is the depth usually of the wood siding vs void vs interior wall ? The reason I ask is, looking at some of the responses something like 3/8" lags seem to be the way to go. As most of those are 5" or longer, wanted to make sure that I didn't pierce into the interior wallWould not sit well if that happened.
@Q, thanks so the 3/8" x 5 should be good without going through the interior wall and taking out a TV, ceiling fan etc ?![]()
That should be a perfect size to adequately piece a heating pipe and cause you to bear a $2,000.00 repair bill.![]()
Your best option is a proper bracket. If that won't fit, then perhaps it's time to consider other DIY options, however, as you identified screwing deep into a wall is not without risk. If you can get the plans to your house, the wood should be specified. What you don't want to be doing aside from screwing all the way through, is just screwing a bracket that's got a heavy load on it just into the clapboard or trim board as the screws will likely pull out. You really need to be a good depth into the post without going through. With a bracket where the holes on each side are opposite each other, you want screws that stop just before 1/2 way to stop them meeting each other. Pipes and cables can be found with a detector, although beware they're not always 100% right, especially DIY priced ones. Also, a bit of common sense goes a long way here. Take a look at what's in the room behind the corner where you're going to screw for obvious signs of pipe work or cable routing. It's not fool proof but a visual inspection is a good place to start, followed by detecting etc. If you want to know the exact dimensions of the corner post, another option would be to lift the end of the trim board at the top or bottom of the wall and peak behind, then tack the trim board back.
Thanks @Q that is just what I need to take my DIY experience to the next levelshame that SPAX don’t do a 3/8” exterior powerlag in a shorter length though.
Any of you mounted foam behind the bracket or junction box to create a sandwiched layer of sound insulation for the rooms beyond the exterior wall
Yes I've reset the 59225 back to defaults and reconfigured everything from scratch, it doesn't seem any different to just upgrading so far.
The limited information is still there under the lifetime stats compared to the older versions - not sure why they've hidden it unless they want to start making some of them warranty exclusions and they don't want end users having the ability to see this?
I've been away from home a couple of days and I have noticed something weird.Do you still approve of this firmware?![]()
