mrlindstrom
- May 21, 2014
- 12
- 1
Do the ANPR cameras like this require an NVR or can they be set up to send/store plate matches somewhere else like on an sd card or uploaded to an ftp server?
I use my two 437s with BI. Acts very much like an ordinary camera except the license plates are much better at night than I was able to ever get with the 5231-Z12s.Do the ANPR cameras like this require an NVR or can they be set up to send/store plate matches somewhere else like on an sd card or uploaded to an ftp server?
I'm using Edge in IE Mode and the images and search functions work fine for me.Same problem. Live works fine, although only displays events since current login.
But search does not.
I have tried various browsers / modes on both Windows and Macs. Nothing works. Is there any way to directly mount the SD card on a computer, without pulling the card?
I got that September 15th one from @Billyjack5 and uploaded it to my camera, first impressions are that the v5 stuff for this camera probably isn't quite ready yet. I made a quick and dirty video that shows how it looks and some of the initial findings:I've been in contact with Andy about the firmware for the 437. The firmware my camera shipped with is dated 2023-02-04. It uses the old interface and generally works fine.
There are three other firmware files released since--one from April 2023, another from July 2023, and most recent is from September 2023. Andy doesn't have any more stock of the 437 camera so he can't test them.
The three firmware files after the 2023-02-04 version use the 5.0 GUI. The July and September 2023 files have an updated plate algorithm based on the system info. When I flashed them, the files flashed fine but I wasn't able to get the snapshots to appear in my browser in realtime and the ANPR events weren't registering on the SD card (manual snaps, though, appeared in the snap window and recorded on the SD card). Admittedly, I didn't do extensive testing to fix. I ended up rolling back to the 2023-02-04 firmware with the old interface.
If anyone wants these files Andy has them or message me and I'll send a link to you to download. I also have the 2023-02-04 firmware file if anyone needs it.
There is no newer 437 anymore, this is the last stocks for the 50mm lens.
Another higher model is this one. But costly.
ITC431-RW1F-IRL8 - Dahua International (dahuasecurity.com)
10-50mm is the right one, i sold 10pcs of this one, work really good.
I was going to try it, but Andy told me there had been reports of losing support for USA license plates, hence I passed.Just wondering if anyone here with the 437 is running the most recent firmware on Andy's site, which is dated 7-26-2024? The last three I tested from Andy were from 2023 and I didn't use for various reasons. Just wondering if anyone has had luck with the newest, and I presume, last firmware for this camera.
That's helpful. Thanks. I've had my 437 for a couple of years now and, like the 237 I had before it, the time settings won't stick. After syncing with the PC or turning on the time server option, the snaps will have the accurate time for a few hours and revert to an inaccurate time. Using old IE and Edge in IE mode, neither work. Anyone have a trick for this?I was going to try it, but Andy told me there had been reports of losing support for USA license plates, hence I passed.
If anyone can confirm one way or the other would be great.
Just DM'd you the link.Panic. I foolishly upgraded to the v5 GUI for the 437 camera (from Empire). It sucks, unusable.
Does anyone have a link for the older versions from 2003? I reached out to Any @ Empire a few days ago, but got no reply.
My camera that I upgraded is basically offline the firmware is so bad.
