itm
To confirm what I've done (and have just done again):Try to pair the camera again with the EZViz app or remove the camera from the app and then add it again.
Did you test the Sage sensor for function with 12V?
1. Delete the DB1C device from the Ezviz app
2. Press the reset button on the DB1C
3. Add the DB1C to the app (scanned the QR code)
4. Selected Electronic chime from the options
5. Pressed the doorbell.
6. Got the incoming call, but no video stream
7. Tried to access the video stream from the Ezviz app, and got the "Operation failed" error.
8. Tried to access the video stream from the Ezviz app again, and got "Device offline" - the DB1C has now powered itself off.
I haven't done the 12V test with the Sage sensor yet - do I need the current sensor NC/NO switch for that, or do I simply connect the + and - terminals of the transformer to the Green and White connectors on the Sage sensor? If the latter, what would I look for to indicate success - e.g. should it trigger my "First Button Pressed" automation when I connect the transformer?
