bigredfish
I havent used the 5442 bullets yet. I have the Zoom dome in S2 and S3 and the S3 introduced a much poorer image. I use the S2 on a junction to capture accidents with no AI, plus doing face detection at a local business entrance. Now I have dozens of S3 in the field.
I found the 4/8MP S3 need to be at least 40-50% zoom or the image really suffers for any kind of digital zoom/evidence sharing, the S2 had less issues with that, the new chips changed it considerably. I generally only use them zoomed in anyway. Though the fixed lens 4MP also suffers in wide angle for digital zoom. I do use them for small areas and they are good in low light, but if I want clarity I get the 8MP model .. then its darker at night but have to take the good with the bad. I have run the 8MP in 4MP or lower and still got a better image than the 4MP 5442 in 4MP.
My ONLY reason for using the 5442/5882 now is for the AI. I use other Dahua cameras for anything else. I only use the 8MP zoom at car park entrances or where vehicle/human/face pickup is further away than the 4MP can capture. I have 17 AI cams on my last job. Avg clients have 32-64 cameras. Only using Face Rec and Metadata right now as the 608 NVR firmware had issues with Acupick.
Last thing to add is with either of them when you use Face Detect or Metadata the image will get worse and you need to adjust it.
So only use AI if you need to. I have the 4MP Starlight and I could not even use AI on that as the picture was so bad with it enabled. Instead I enabled the NVRs face detection. Also default settings revert to a messed up shutter that causes lines and darker image. Firmware bug in all of the S3s.
I dont even know where to start.
- You're referring to digital zoom multiple times. Digital zoom on ANY camera creates artifacts and is a poor replacement for the proper optical zoom/lens
- I would like to see an 8MP camera (what model?) running in 4MP resolution that outperforms a 5442 S3 at night in low light which are as the model number suggests, 4MP
- The 5849 ASE LEDs with the 1/1.2 sensor are great cameras. But they are limited in their lens choices and close focus distance. They are S2 and have not/will not likely be updated to S3. So yes given enough light (no IR on these) they can perform very well
- What "other cameras" do you use that aren't AI that you "use for anything else"?
- Can you show an example of a 5442 or 5842 where using VMD makes the "image will get worse and you need to adjust it??
- Do you leave most of these cameras you install at default settings?
- What model camera is this referring to? "4MP Starlight and I could not even use AI on that as the picture was so bad with it enabled.?
- What? "Also default settings revert to a messed up shutter that causes lines and darker image. Most default settings do the opposite as they are set from that factory at 1/30 and made to be very bright.
- What fw bug? " Firmware bug in all of the S3s."
Have you tried the new 5459 or 5859 ZE PV PRO cams? They’re very bright. Sounds like you would like them
