Chokolinho
Thank you very much. I have ordered the camera for testing.They are for all intents and purposes the same camera, different form factor.
Though the ZHE has a better/bigger F stop but the Turret has stronger IR
A Poe switch with 4x 100mbit should be sufficient.Anyone know the mbps this camera uses.. Im wondering if a 10/100 switch with 4 of these cameras running will be plenty?
Your talking about wattage.. im curious what the bandwidth one camera uses on full/high quality settings.. Thank you though!5-10 depending on IR
I think mine runs about 6 mostly
Sorry, read too fast
I run 30FPS, iFrame 30, 10240 bitrate, CBR H.264.H on that fixed turret
How high is the camera mounted?I dont seem to be getting as bright a picture as you looney2ns.. This video is with 0-16ms shutter speed and 0-40 Gain. This neighborhood has no street lights so maybe that is why..? Camera is about 9 feet up and 60 feet to the street.
Thanks for the reply! The camera is 9 feet up. It was the lowest i could get it and keep the cable in the attic. I may try adding a IR light to help.. I will bump the gain back up to 50, Thank you guys!How high is the camera mounted?
What are the shutter settings ? Try 60 gain.Thanks for the reply! The camera is 9 feet up. It was the lowest i could get it and keep the cable in the attic. I may try adding a IR light to help.. I will bump the gain back up to 50, Thank you guys!
Shutter is 0-16.. will try 50 then 60. Thanks!What are the shutter settings ? Try 60 gain.
3d nr settings at around 40 ?Shutter is 0-16.. will try 50 then 60. Thanks!
I think thats about where they are at.. I am away from camera until tomorrow.3d nr settings at around 40 ?
Money was tight so was only able to get 2 cameras.. But at least i talked her out of buying the amcrest system. Im pretty sure that would have been a complete disappointment.Ultimately when you're done trying workarounds, you'll need to aim the camera out more and lose that little slice of the garage or accept that you need another camera to do the two jobs
You definitely need some external IR light. If you don't want to mount them outside, you can place them inside and shoot through the window. When using lots of IR light, you can use a faster shutter and diminish the motion blur from target moving. I have the compound lit up like Times Square with IR light.I dont seem to be getting as bright a picture as you looney2ns.. This video is with 0-16ms shutter speed and 0-40 Gain. This neighborhood has no street lights so maybe that is why..? Camera is about 9 feet up and 60 feet to the street.
