I am about to add some more cameras to my
Blue Iris system, and it looks like two of these would be about perfect, combined with a panoramic pointing straight out of the driveway. What do you all think about pointing these out to the county road to capture the meth-heads casing places to rob? I'm not concerned about LPR right now, just capturing the traffic. I'm currently using a solar Wi-Fi Reolink Altas which has been surprisingly good, but the lag is unacceptable.
My plan is to put one of these on each side of the driveway, pointing to the opposite side - the east camera points west, and vice versa. Then using the triggers to make sure that the center, wide-angle cam captures them right in front.
As you can see, the distances are not prohibitive, only about 25-50 yards/meters.
I welcome any and all comments and suggestions.
* EDIT to add links to the two cameras I'm considering at the moment. *
3 × 2MP 1/2.8" CMOS image sensor Built-in 8 IR LEDs, the max. illumination distance is up to 100 m Supports long-range perimeter protection Deep learning algorithm Supports max. 1TB Micro SD card Supports two-way talk ePoE IP67 and IK10 protection
empiretech01.com
Outputs 180° wide angle splicing image Outputs max. 8 MP (4096 × 1800)@25 fps Built-in warm light, and the max. illumination distance is 40 m Supports max. 512 G Micro SD card Built-in Mic and speaker, support two-way talk 12 VDC/PoE power supply, easy for installation IP67 protection...
empiretech01.com
