Bob Schulz
Pulling my weight
Try to play with Web UI, conditions manual, set 0 for both. You might have to change multiple profiles.
That did it. Thank you
What is the latest firmware for these? Thinking of playing with autotracking again. @EMPIRETECANDY
Currently running:
System VersionV2.623.0000000.13.R.E4.4510.UN.NR, Build Date: 2018-12-05
WEB Version3.2.1.667589
ONVIF Version16.12(V2.4.3.574996)
PTZ VersionV2.400.0000000.10.RHNAD_171212_5259
S/N4M0742APAJ752D8
Security Baseline VersionV1.3
Dahua Technology - World-leading Video-centric AIoT Solution and Service Provide
Dahua Technologywww.dahuasecurity.com
Are you looking at where a fixed camera can trigger a ptz to move to a preset? If so I think you need an nvr52xx to do that.I've been following the auto tracking thread (Dahua poor auto tracking - What am I doing wrong?) and have noted that one of the other PTZ cameras has the ability to trigger a preset when a tripwire or intrusion box is activated. I know my current firmware, which is not the latest, does not offer that option. Does anyone know if the latest firmware provides for this functionality?
You can leverage triggers from cameras (built in or BI trigger)and have Blue Iris send a PTZ to a fixed position.Are you looking at where a fixed camera can trigger a ptz to move to a preset? If so I think you need an nvr52xx to do that.
Makes sense to me, something has to coordinate.Yes but I don't think you can do it natively with standalone cameras can you? I believe you need an nvr or BI to communicate between cameras.
I've ran it for a week so far. No issues.Has anyone tested? I need to figure out NP vs PN it looks like from that search.
Just the single largest bin file.Apply all bin files? Skip the one with boot in it? @looney2ns
I always do a before and after factory reset.Factory reset after upgrade? Is before (with full IP reset) needed as well normally? @looney2ns
AI features are not added.
