EMPIRETECANDY
IPCT Vendor
can buy 10 49225xaFor a few thousand dollars, right?
Yes , I do !
Some of the pic are very bad and not clear - maybe this is a result of night caps. Sometimes a male is a female !
yep...a nice juicy 500w available with POE+POE+ switch, right?
Is there a trigonometry mathmatical equation for optimum height? Or do folks just slap it up high out of reach/out of high obstacles?
| Power | |
| Power Supply | DC 12V/3A PoE+ (802.3at)  |
| Power Consumption | 13W 22W (IR on)  |
Please read the specification on the camera ,500W is a massive overkill and would be a BIG waste of money
Something like the below which is also AT compatible and well enough for this camera
Tenda POE30G-AT 30 W IEEE802.3 Gigabit PoE Injector, power distance extension of up to 100 meters for standard cat. 5e and cat. 6 Ethernet cable , Plug and play, no any configuration required,: Amazon.co.uk: Computers & Accessories
Excellent points. Thank youPTZs tend to be installed higher as they have a longer range, so at a distance 200-300 feet out (or farther - I can clearly make out strangers at double-triple that during the day), the difference in height (provided it is like 20 feet high compared to a fixed cam at 7-8 feet high and not 300 feet high LOL) is not a big difference.
Obviously then when someone is closer to the PTZ, the same issues we see with a fixed cam installed higher come into play. But if you have a two story and install the PTZ up there you will then take advantage of the range the camera has and when looking at someone at a distance of 300 feet the viewpoint will be appropriate.
took forever to figure out how to successfully implement the onboard VPN Radius server in my Ubiquiti UDM (no mention anywhere that I had to allow the IMGP ping for things to work). Due to recent security events around my place, I had to slam into my head figuring out firewall rules & profiles and vlans and subnets. I think, I am AOK for time beingIf you need any assistance just reach out as always. Also great pick on the Unifi gear, run the same myself on a number of installs full Unifi stack so if I can be of any assistance in the Unifi config let me know.
