@rcirz that is now where you will want to define Target Tracking Size and Alarm Track time which will help with this. Also ensure you don't have IDLE time or Tour's conflicting that are pulling your PTZ back to a preset etc and tripping you up.
As I mentioned in another thread LOCATED HERE, you can still use PTZ Activation (call to preset) and nested presets BUT if you want to use with Deep IVS, the options change as I explain there. If you use with an NVR then you can set it up in there for the channel as I list in that thread. Take a look at that post and as always if you need any help, reach out.
Got the new firmware and autotracking works pretty well but it is a new learning curve for me. I am trying to understand the logic. Now, tripwires and intrusion boxes no longer have an option for sending the camera to a preset. It seems that when an event is triggered, the camera will attempt to track the object in the direction of the closest preset in the direction the object is traveling and goes to that preset. Sometimes it zooms, sometimes it doesn't. I also had instances of the camera picking up an object and starts to pan to the object and then in a flash, it goes back to the home position, like it was scared lol. I am glad I saved my cam config file so if things aren't as useful, I can go back to the firmware that allows Deep IVS to go to presets. I am definitely not giving up. It is exciting to have tracking that doesn't spin my camera like a top. Lots of testing to be done.
