@rsoxhater I generally go with the more ends up being less approach with OpenALPR. Specifically that through processing the actual FPS OpenALPR will always be less than what you feed it.
Therefore I run:
Side note, I also have a potential 4th capture stream as well for OpenALPR as I use tripwires on 1 LPR cam to force a PTZ to a preset choke point that is dialed in that it can also get plate + model if needed. By the time the tripwire is tripped the PTZ is in position and waiting for the vehicle
HTH
Therefore I run:
- Sub Stream = Sub Stream 2 is the RTSP that I generally pass (depending on the cam of course)
- Res = full HD (1920 x 1080)
- FPS = 30 (usually see this process at 10 - 15 through OpenALPR)
- Iframe = 30 (set to match FPS)
- Bit Rate = (high, usually between 8192 & 10240)
HTH
Also, here is the link for the 2 free camera licenses:
Public Safety Software Donation - OpenALPR by Rekor
A software donation initiative designed to provide organizations with valuable data to reduce crime and increase safety. Register now to receive two licenses.rekorsystems.com
