Does This cam in video Structuralization mode process IVS tripwires/intrusions with human/vehicle filtering?
Or You can only choose between IVS and video structuralization without possibility to use booth (even with some limitations)?
Did you reset the cam to factory defaults after the update? Set it back up from scratch, don't import a settings file.I updated the firmware on this camera to the newest version provided by Andy. I'm seeing alot of greying out on video capture now in OpenALPR. Is anyone else seeing or experiencing this? It seems to only happen to cars in the right lane, cars captured in the left lane seem to be perfectly fine. It doesn't happen to every car.
I just ran the first firmware he sent, then was showing an algorithm mismatch error in the settings and he sent me another one to apply which resolved that mismatch error. I haven't done a factory reset, I don't think he said it had to be done, but I can give that a try. There is a multitude of new options on the camera, I'm wondering if one of them is somehow messing with the openalpr feed.Did you reset the cam to factory defaults after the update? Set it back up from scratch, don't import a settings file.
I should also add, the camera froze up 2 times, and I had to power cycle via unplugging the camera and back in which is why we did the firmware upgrade.I just ran the first firmware he sent, then was showing an algorithm mismatch error in the settings and he sent me another one to apply which resolved that mismatch error. I haven't done a factory reset, I don't think he said it had to be done, but I can give that a try. There is a multitude of new options on the camera, I'm wondering if one of them is somehow messing with the openalpr feed.
Looks like OpenALPR has a hard time decoding the video signal from the camera. Could be the network link, but probably the encoding parameters (e.g. VBR/CBR, H264 vs H265, frame rate, I frames etc). You may want to try changing those parameters and see if that does anything to the grey picture on OpenALPR.I did a bit more investigative work on this - See the video here. On the left hand side is the openalpr config, and on the right is the dahua live view. It seems to be specific to openalpr. I have an open ticket with them already, but I am wondering if one of the new settings is messing with the openalpr feed. There is a new version of openalpr version available as well.
newwindsor-ny
newwindsor-ny.tinytake.com
newwindsor-ny
It just started with the firmware upgrade on the camera, before there was no issue. I am going to play with the connection strings today and see if there is any difference, and also try the new version that has been released of the openalpr. Also will try a factory default and then reconfigure the settings.Looks like OpenALPR has a hard time decoding the video signal from the camera. Could be the network link, but probably the encoding parameters (e.g. VBR/CBR, H264 vs H265, frame rate, I frames etc). You may want to try changing those parameters and see if that does anything to the grey picture on OpenALPR.
I would replace that wire as well while you are up there.So a bit more information on this. Tuesday I had our building and grounds guys throw the breaker to the pole, which killed power to the switch. This should have power cycled the camera the same as unplugging it from the switch. No change at all, camera was still down.
The previous two times I had put a ladder up to the pole and pulled the wire going to the camera and then put it back in, which brought the camera back up. Today I put a ladder up there to verify the wire was good (it was). While I was up there, I pulled the wire out to the camera and put it back in, and the camera back online. I'm going to replace the switch there, maybe there is an issue with that, but the other camera on the pole has no issues and its connected to the same switch, but uses external power, not POE. Path of least resistance before bringing in a bucket truck to get to the camera, and police to stop traffic.
On another, better note, I fixed the Open ALPR grey issue. With the new firmware, changing the connection string from generic to H.264 over RTSP using TCP fixed it, and its no longer greying out. Other connection modes would connect but get the greying out issue.
Yes, if the new switch doesn't help it then I'll do the wire as well, but will need the whole bucket truck and police setup. Unfortunately I can't get a fluke on both ends of the wire, but with it on one side it didn't show any shorts.I would replace that wire as well while you are up there.
1. I noticed that while you were on your porch, the camera AI counted you as +3 humans. Does that mean it doesn’t save your image to a database in order to detect same/returning person later? (Figured out while writing and re-reading this thread that I probably need ZFR model for that.)Post # 2 - Reserved For Initial Pics & Vids
I am in a dead-end alley and it would be amazing if I could get an alert for every unknown car that doesn’t have owner in our alley. This is a sort of a database building. There just isn’t one for faces/people for this model it seems.Black & Whitelists can be built and saved to the AI NVR with ALARM OUT options when a plate is picked up matching one of the lists
AI processing is on camera so you don’t need internet for the AI in cam to work
Don't worry about what is listed on his web sites. Send Andy (@EMPIRETECANDY ) an email at [email protected] and see if he has it or can get it.but I didn’t find the Z version in Andy’s shop, only Z4.
2. Is the tested camera different from the HFW7442H-Z4 version only by max focal length 32mm instead of 12mm?
3. Was just reading a reply from Andy and he told me these kind of AI cameras require special types of NVRs to get all the AI functions working: “Pro 4.0 AI NVR”
I didn’t quite understand if that meant any “AI” marked NVR? Like:
US $270.49 5% OFF|New AI Network Video Recorder 4216 I 16Channel 1U AI Network Video Recorder , free DHL shipping|Surveillance Video Recorder| - AliExpress or
US $701.0 5% OFF|New AI NVR Ulrta Smart 5216 16P I 16Channel 1U 16PoE AI Network Video Recorder ,free DHL shipping|Surveillance Video Recorder| - AliExpress (more expensive)
Which one did you use? Is it worth going for the more expensive one for home use (more bandwidth, more computing power I assume but there was no CPU information)?
I think this camera will be perfect to control the road as I can mount it only 60ft from middle of road and only 25 degrees angled from facing plates straight on. Should work excellent day and night and is probably an overkill for my conditions but I didn’t find the Z version in Andy’s shop, only Z4. ZFR is definitely not for me as I need to keep ANPR more. Sigh, would be nice to have both
This looks exactly what I want:
4.Just to be sure: I don’t need any 3rd party subscription or making any API calls over internet for simply saving/analyzing the license plates and saving (not recognizing!) images of people walking by?
Foud it later in thread, thank you!
