Review-Dahua IPC-HFW5241E-Z12E AI Varifocal Bullet
but what's the horizontal range of movement
So there is a ball (silver color) positioned in the socket (white cylinder). This allows almost 90 Deg. up and down vertical movement. That socket can be rotated 360 deg. in the mount plate on the end.
Reactions: looney2ns
I have a 5241 and 5231 that I am testing for LPR's. The 5241 was bought from Andy on Amazon (the 4231 may have been as well).
Tripwire is not working on the 5241 and 5231 tripwire misses about half the cars that cross it.
I upgraded the firmware to the one listed here on the forum (R16) on the 5241 and the 5231 is on the latest I can find.
They are powered by a POE switch, have the tripwires setup up and the Smartplan is set to IVS on both camera.
Device TypeIPC-HFW5231E-Z12E
System VersionV2.800.0000013.0.R, Build Date: 2019-12-02
WEB VersionV3.2.1.825578
ONVIF Version16.12(V2.4.3.822559)
Security Baseline VersionV1.4
Device TypeIPC-HFW5241E-Z12E
System VersionV2.800.0000000.16.R, Build Date: 2020-05-29
WEB VersionV3.2.1.900200
ONVIF Version19.06(V2.6.1.845551)
Algorithm Version1.0.1
Security Baseline VersionV2.1
Any ideas?
Thanks.
Any ideas?
Thanks.
Get OpenALPR if you are going to record license plates as it does not miss cars as long as they have a plate and the accuracy is pretty amazing. More than worth the $5 per month and all the time your are going to waste trying to get
tripwire working with cars, etc.
Any ideas?
Thanks.
Try playing with the tripwire line length and target size. On a different Dahua camera I found sometimes the proportion of object to trip line size was a problem. Another time I had the minimum target size too big.
Ive had similar problems with both models and IVS.
I set regular old MD in addition to IVS at night only. I'm now getting 100%. Not fancy but it works fine.
Any ideas?
Thanks.
Sometimes, in some situations intrusion works best.
I would read up on this in the LPR subject area. LPR | IP Cam Talk
Use this latest new firmware, it's working great.
Updated model 5241-Z12E-S3 mini review here:
Amazon Link
