YesSorry if I missed it but this camera can also be powered by an optional AC adapter instead of POE?
No word of that. Even with the newer 5442 series, there are no varifocal turrets.Any word on if they plan to produce a turret version of this anytime soon?
No word of that. Even with the newer 5442 series, there are no varifocal turrets.![]()
How is this model compared with the 1831 fixed lens?
@Arjun you'll find the 1831 a little brighter thanks to its f1.6 vs f1.9, in my real world testing although that makes a difference, nothing means more to 4K cams at night than AMAZING lightThat is with the exception of the new Ultra AI series where you see apertures down to f1.2 (which helps a great deal). If you don't need a VF cam or an SD slot then the 1831 is still a great little cam, just remember positioning of install and lighting and that will help you maximize what is possible from these cams. I will say again though that (with the exception of the Ultra AI 8MP/4K now showing a lot of promise) you would still want to augment the 1831 with a low light / night killer like the x5442 variants (if you want 4MP) or the x5241 variants (2MP and Andy's @EMPIRETECANDY successor to the 5231). One bonus (whether important to you or not) is these cams are also part of the Pro AI family so you do get some extra features on the x5442 and x5241.
Is the difference drastic or just mild? I'm hearing different opinions from other users as well.
Drastic or mild, do you mean the image difference between the 2 ? If so, what are the details on your install location and specifically lighting in the area ? Also what are you trying to do with the cam, overview, face shots, augmenting other cams ?
Might be worth posting this question in the LPR sub-forum, if you haven't already ... might get the attention of more folks with LPR experience.Think this would be good to catch license plates if I zoom it way into the street, from right next to the street?
