I have had this camera running for some time now. And now everday I loose connection and have to power down and re-power the cameras.
Anyone else have this issue?
Are there logs I can check to see what the problem is?
Did you figure out your issue. I figured mine out today it seems. A few pics I took, not super relevant. Anyway my cam was rebooting over and over and kept loosing connection many times a day. I noticed if I tried to set auto maintain settings, when I would reboot the setting would be blank again. Same thing with IP address, it would change, and reset to it's previous setting on reboot.
So I bench tested the camera with a small cable in the closet, no luck... Reset the camera, no luck.... hard reset the camera at which point settings started to persist through reboots. Still camera would go offline and online within minutes. When mounting it the final time again I said well let's take out the Micro SD card. Since I took out the card the camera has not disconnected 1 time in 6.5 hours so far. Pretty sure this was our problem. We are going to try a new (better hopefully) micro sd card and see what happens.
Has anyone with this camera swapped out one of the lenses like in this video?
If so, am curious what lens was used. I've got the perfect spot for this camera with a 2.8mm and a 12mm or slightly longer lens for the other cam and wanted to make sure that I bought one that is confirmed to fit.
				Or go on aliexpress
BICK
Take a look here: EmpireTechAndywhat is the latest English firmware for this model?
I was checking around the downloads section, but didn't see anything for this camera.
Thanks,
gary
As I reported in my OP, this puppy runs rather warm. I would be conscious of how it is mounted to facilitate as much heat dissipation as possible from the base.Wow, good to know! I will give it a try tonight and report back.
Make sure that somehow one isn't H264 and the other H265 - make sure they are the same.
Also, open it in Internet Explorer and delete the add-on in IE and let the camera reload them.
Might not be it, but worth a shot.
