flynreelow
- Dec 12, 2016
- 1,562
- 1,439
Channel 1 and channel 2How do you convince BI (4) that the one IP has 2 cameras?
This exact info was detailed on the first page of this thread.
Sometimes when you are frustrated because you can't get something to work right, it is easy to miss things. I had the same problem when I first got this cam, and even though you indicate "This exact info was detailed on the first page of this thread", it isn't or if it is I am blind. You mention the word 'channel', but in reality, to get this camera to work in Blue Iris:
1. Create two cams with the same settings
2. Under 'Video Tab > Network IP > Configure > Video Path'
/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
/cam/realmonitor?channel=2&subtype=0&unicast=true&proto=Onvif
Umm ok. Wow.Sometimes when you are frustrated because you can't get something to work right, it is easy to miss things. I had the same problem when I first got this cam, and even though you indicate "This exact info was detailed on the first page of this thread", it isn't or if it is I am blind. You talk about 'channels', but in reality, to get this camera to work in Blue Iris:
3. These are the actual parameters that need to be used: first cam - channel 1, 2nd cam channel 2
Umm ok. Wow.
I'm new to the forum - and I see a lot of people recommend Andy for Dahua Cameras - I prefer to install dahua over hik for a couple reasons - but I'm noticing - none of Andy's camera reviews have logos on the camera bases like normal dahua cameras I buy - how do we confirm these are Dahua cameras?
Ok, another problem geeezz.
I've got the dual headed HDBW4231FN-E2-M (3.6mm & PAL) set up and mostly working Except for:
I've set up different intrusion zones to take snapshots for each camera using the IE interface of settings and IVS.
Using SmartPSS (which is the same version I've been using for my SD49225's) My No. 1 camera shows the Intrusion zone and takes snapshots, the No. 2 camera does neither.
I've also got both heads continuiosly recording to a Dahua NVR 4104-P-4KS2NVR.
Does anyone else have this problem? - or a solution?
Thanks
...and Yes IVS is checked in SmartPSS for both heads
...actually, after spending a couple of days trying to get the #2 camera to trigger off of anytrhing I've come to the conclusion the Dahua fiemware and or SmartPSS/IE IF does not enable the #2 camera to be triggered by any means.
About all I can get the #2 camera to do is record continuios video. The #1 camera will intrusion trigger off of shadows and lighting changes but rarely off of people/animal intrusions.
Same here. No luck whatsoever getting camera #2 to do anything with IVS via directly through the camera, NVR, or otherwise.
Not sure what you mean, but: https://www.amazon.com/EmpireTech-I...7632959&redirect=true&s=merchant-items&sr=1-7Anyone know if this model is being superseded with the new range? Can't seem to find anything, looking at maybe buying one of these. Thanks.
Ok, normally can contact us directly, we can’t check altoo many messageWe did notify you back on August 14 & 15 Andy, but got no response. It is nice to know that you do respond to reviews on Amazon.
