johnnyappleseed
Does this have POE? I am doing a new house build right now and really have only been planning on running ethernet cable, not 2 wire doorbell wire. I've been looking at the VTO2111D-P-S2 but this looks smaller/sleeker.
Nope.Does this Dahua doorbell accept Dahua HTTP CGI commands over port 80 and expose events? Apparently the Dahua subsidiary Lorex 2K doorbell doesn't.
I have not had a VTO2111D-P-S2 to test, so I can't answer other than the VTO has POE, which in my book is a plus.Any glaring advantage (other than price) of this over the VTO2111D-P-S2 ?
Too bad the vto models are lower resolution than the doorbell version. As you said, no perfect product.yeah.. 2301 has poe.. found it also a few days ago. also discussed in another thread here.
All old VTO can be used as standalone, no need for display. You can register the app directly.
Only problem is, that you cannot add a chime to it. Dahua dont want to link the relay in the firmware to the button press.. always the chinese favour of a half perfect device. They are obsessed with it for some reason.
The Amcrest models do come with a chime kit and it is essential for connecting to an existing chime. That is how mine is hooked up and it works perfectly - using the existing 52year old 24vac transformer, wiring and mechanical ding-donger. Surely all these other Dahua variants also come with a chime kit. If you are saying that your package did not include the chime kit and you connected the doorbell without it - well, maybe that's why both had failed.I will say, if this is anything like the amcrest version, you might as well figure it as not having a chime relay either. Seems if you hook it up to a chime, there's a high probability of frying it.
I just desperately need to get rid of those awful Skybell HDs I have now!
Mine came with the chime kit, I used the chime kit, the first doorbell died after a week, the second lasted 5 minutes. I spent literal weeks going back and forth with amcrest who confirmed I had everything wired, and configured correctly.The Amcrest models do come with a chime kit and it is essential for connecting to an existing chime. That is how mine is hooked up and it works perfectly - using the existing 52year old 24vac transformer, wiring and mechanical ding-donger. Surely all these other Dahua variants also come with a chime kit. If you are saying that your package did not include the chime kit and you connected the doorbell without it - well, maybe that's why both had failed.
Yeah, I had Skybell HD originally too, and am definitely glad to get rid of it.
Even if I go with this camera, I'll have to build a relay to trigger the chime, because I already lost two ad410 doorbells by hooking them up to my existing chime, I won't do that again. So might as well use VTO, at least you get Ethernet for stability. Of course you also have a bulkier device on your doorframe, and lower resolution, so there's no winning.
For security applications fps is a waste. I also hadn't seen those disappointing field of view angles. Nor had I noticed that the lower resolution is also at a worse aspect ratio.
If you can't see how more resolution allows you to identify more people though....
Yikes, this certainly isn't making those door stations look any more appealing! Wish they'd put a better camera in them.
For exactly the same reasons I stated the first time, with higher resolution you can identify more people at further distances. Given your argument, you might as well save bandwidth by having a two pixel by two pixel sensor. You won't be able to see anything, but apparently that's not important.I think you dont understand these doorbells. why do you need a better camera inside? its a doorbell, not a surveillance camera.
1. if they would put a better camera inside, the housing would be huge
2. if they would add a better processor/sensor, the price would be higher
3. the fish-eye lens cause distortion, so you wouldnt be able to identify someone over 2m anyway
4. because its 4:3 aspect ratio they may have already cropped the real image and removed some of the distortion with software, which may worse the image already or maybe its a 4:3 sensor, there are no specs whats inside...
5. looney didnt say anything about max bitrate settings, most cheap doorbells have 4096 or 6144 as maximum, with 5mp this is terrible and most not be a huge improvement over 2mp with 8192
6. with the sensor size and the higher pixels the night vision is not the best
7. even if you have lower fps , 5MP eats more space than 2MP, even if you run it on VBR
so i ask again.
why do need a high resolution camera inside doorbell ?
