Arjun
Yes, PFB203W is the right mount for this dual lens cam.
Contact me directly to buy, will Minimum the VAT for you, I Send you a DM.Thansk Andy - what's shipping to UK like at the moment - I think Ali add VAT now so no import issues? The bracket has extra shippign charge as its heavy I think?
Yeah I was hoping to use it as a doorbell cam but I need two way talk as well....2 way audio would have sealed the dealI still like the nighttime performance on the 2mp model, both models appear to sport the same sensor
It's perfect for this use case. It has an audio out jack, so you could make it a two way talk by adding a small amplifier and speaker.would this be good as a door cam so you can see people at your door as well as packages on the ground with one cam pointed in each direction? Also does it have two way talk?
unfortunately thats a little over my skill level....thats why I was looking for an all in package ...It's perfect for this use case. It has an audio out jack, so you could make it a two way talk by adding a small amplifier and speaker.
So, the PFB203W is not an option for wall mount?Hey guys.
Unfortunately, I need to mount it on a wall with PFA137 junction box. I see that rain/sun shade PFA200W is compatible with it, but wondering, if somebody would have some feedback to share for this combination - mainly rain conditions, sun conditions etc.
I understand best would be to place it under ceiling but that is not an option for me.
Many thanks.
unfortunately no. It needs to be directly on wall.So, the PFB203W is not an option for wall mount?
I'm not getting what you need. The PFB203W is designed only for wall mounting. Cables come in from the rear of the mount.unfortunately no. It needs to be directly on wall.
@EMPIRETECANDY - many thanks, it would be very helpfull.
