Courtesy of Andy @EMPIRETECANDY today we have the DB-11 Video Door bell.
It will be available here soon: Empire Technology Co., Ltd - Small Orders Online Store, Hot Selling and more on Aliexpress.com | Alibaba Group
Video
Video Compression H.264
Image Sensor 1/2.9” 2MP
Lens 1.9mm
Angle of View H:140°
Day/Night ICR, 5m
Audio Audio Compression G.711
Audio Input Omnidirectional Mic
Audio Output Built-in Speaker
Bidirectional Talk Support Dual-way Bidirectional talk
Operation Mode Keypad Single Mechanical Button
Motion Detection PIR, 5m, H:120°
Network Wi-Fi IEEE802.11b/g/n, 2.4GHz
Ingress Protection IP55
Memory Slot Micro SD, Max 64GB
Installation Surface
Material Plastic
Power AC16-24V/DC12-24V
Power Consumption Stayby<3W, Work <5W
Working Environments ﹣20°C~+50°C
Relative Humidity 10%~95%RH
Dimensions 119.0mm×47.0mm×29.0mm
Weight 0.30Kg
Here is the manual:
Here is the spec sheet:
We are off to a better start than with the Db-10 video door bell. Keep in mind, So far this is based off of the DB-11 residing about 3 ft from my wifi router.
As I don't have a traditional door bell, I'm testing this using a 24vac transformer.
The following works as it should:
We'll see what happens when I move this out by the front door.
Camera porn:
Mounting Bracket
Db 11 on the left.
Video
Lens 1.9mm
Day/Night ICR, 5m
Material Plastic
Weight 0.30Kg
Here is the manual:
- Adding to the Lechange app.
- Manual Video viewing: both SD and HD
- Audio during manaul view-talk and listen.
- Audio Quality from the door bell speaker is MUCH better than DB10....still very low volume.
- No batterys!
- Motion detection alerts, with actual recorded video.
- SD card is recognized and can record to the card (same exact SD card the DB10 still doesn't recognize)
- Pressing the door bell button, alert comes to phone.
- Pressing the alert on the phone, brings up video from the Db11.
Camera porn:
Mounting Bracket
Db 11 on the left.
