fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,417
You failed to read my post. You too are a basic blue iris user and are not using the full feature set of BI so you cannot tell that the camera firmware is defective and are misleading others who will have issues should they use reolink cameras. Take the time to read the blue iris help file. It clearly explains why you need to be able to set the key frame interval in the cameras firmware - reolink does not permit this. IR coverage is meaningless if the sensor is bad and if reolink screws with the exposure to make static images appear good but movement look like crap. The company lies and spams.Guess my Reolink cameras are different as they work fine using BI... Running a RLC-522 and an RC-511. Not the best quality camera, and when they die, I would not replace them with Reolink. But when working, they probably have the best IR coverage for ANY camera I have. Including a Dahua camera I have cost 6 times more. The software options are minimal and you cannot set the iframe rates. But for $50... It's ok. But, they do work with Blue Iris.
Reolink cameras will not last as my RC-511 was replaced under warranty 3 times. Quality is just not good.
