- Feb 5, 2018
- 1,016
- 1,378
All of the Reolinks I have are bullets. And the spider problem is massively annoying, for sure! But as you point out, any bullet will likely be the same. Switching off the built-in IR should help a lot, but with the Reolinks I have, you cannot force the IR off. I did modify one by opening it up and making a foil-cut on the IR board so that it would still be able to switch from color to B&W, but never emit any IR. I have not tried this to see if it helps with the spider webs or not.
I'm not sure if the IR actually attracts the spiders, or if it's just the fact that with the bullet camera, the spiders can spin webs from the little "shade" down over the lens, and thus, have a web exactly the right space away from the lens and the IR illuminators that they light the web up really bright! The eyeball style or turret style cameras with built-in IR would not show the webs nearly as much because the webs would actually be in direct contact with the lens and the illuminators, and the light from the illuminator can't shine on the part of the web that's in view of the lens. I've thought about cutting the "shade" off of one of the bullets to see if that's all it is. Where I have a few, they're in under eaves, and don't need the little shade gizmo anyhow. On the Reolinks, I'll have to saw the shade off of the front section of the housing. They're not a separate piece. But if I was going to do that to any camera, it would be one of the Reolinks that I'd sacrifice to the cause!
