Remote control for electrical circuit?
Webfont
Pulling my weight
Joined
Sep 6, 2018
Messages
138
Reaction score
179
Location
Canada
Anyone could recommend some device that I could install on an electrical circuit that would allow me to remotely turn on/off something?
Something like this, but instead of normal power outlets, something that just exposes +/- wires for a hardwired device, and something that doesn't rely on a proprietary phone app but instead some open standard that could be integrated in a script locally.
tigerwillow1
Joined
Jul 18, 2016
Messages
3,916
Reaction score
8,728
Location
USA, Oregon
Define "remotely". Are you able to use powerline communication? Short range RF? Or do you want to control over the internet and/or wifi?
Webfont
Pulling my weight
Joined
Sep 6, 2018
Messages
138
Reaction score
179
Location
Canada
Ideally WIFI or normal Ethernet so that I could just control that device from my local network by doing http requests to it.
TonyR
Joined
Jul 15, 2014
Messages
17,476
Reaction score
40,699
Location
Alabama
Joined
Jul 8, 2021
Messages
186
Reaction score
451
Location
Oregon, USA
Webfont
Pulling my weight
Joined
Sep 6, 2018
Messages
138
Reaction score
179
Location
Canada
That might be exactly what I need!
But I need to check if I have a neutral wire up there;
Working without a neutral line No
Webfont
Pulling my weight
Joined
Sep 6, 2018
Messages
138
Reaction score
179
Location
Canada
Thinking about it again, that Shelly 1 UL will work; I got confused with a light switch where I don't have neutrals.
The device where I want to use that Shelly is already under constant power with no switch in the circuit so it must already have a neutral wired to it by default. I'd just be reusing those wires and running new ones from the shelly to my device.
In their example wiring in the documentation, what does SW correspond to?
SWSwitch (controlling O) input terminal
Isn't very descriptive to me. Why would you wire up an extra physical switch for your shelly switch?
And the I/O terminals I'd just wire up my device in there right?
ILoad circuit input terminal
OLoad circuit output terminal
"Load circuit input/output" isn't very descriptive again, they just mean "your bulb's + and - wires", right?
Webfont
Pulling my weight
Joined
Sep 6, 2018
Messages
138
Reaction score
179
Location
Canada
Thanks for that color coded diagram, that clears up any confusion I had.
Joined
Jul 8, 2021
Messages
186
Reaction score
451
Location
Oregon, USA
I had to LOL because I often sketch out electrical circuits that I'm going to be working on. For example, I replace a lot
of regular switches with Z-wave switches, and some of the 3-way and 4-way circuits you have for porch or outdoor lighting can
get tricky at times. Well, it's always difficult to sketch the neutral wire, of course, because white lines don't show up
too well on white paper! :wtf:. I've used the old two pencil lines, a gray marker, etc. You can't use a red marker because
the traveler wires are often red. So a friend of mine who is an electrician uses a blue pen for the neutral wire because
BLUE rhymes with NEU in NEUTRAL, and we jokingly call it the BLUETRAL wire.
@TonyR and I are on the same page with wiring diagrams! :thumb:
Anyway, excellent information here on the Shelly devices and wiring them up!
TonyR
Joined
Jul 15, 2014
Messages
17,476
Reaction score
40,699
Location
Alabama
Blue is also the color for the neutral conductor in Europe so it's a "win-win", IMO. :cool:
To be honest, I was a tad lazy, I took someone else's drawing, erased and redrew a line here and there to put the neutral on the screw threads (they had it coming in on the top of the bulb) and erased a couple of lines running to more downstream wiring and made the junctions more obvious with dots, blue or black, as appropriate. That makes real-world 3D wiring more obvious in a 2D drawing, IMO.
Webfont
Pulling my weight
Joined
Sep 6, 2018
Messages
138
Reaction score
179
Location
Canada
Speaking of the Shelly stuff, what other devices from them are you guys running?
jaydeel
BIT Beta Team
Joined
Nov 9, 2016
Messages
1,202
Reaction score
1,280
Location
SF Bay Area
I've also been using another Shelly Wifi Motion Sensor under an eave for motion in the front yard.
While the sensor is not rated for outdoor use, I've been using it without issue since Sep 2021.
I installed it after we had a visit from a wild boar and my cameras did not trigger. Not sure why. But I decided to try a redundant motion detector.
(Fortunately this visit did not result in lawn damage like some of our neighbors that very night. In this case, the boar pictured above was scared off by my motion-triggered sprinkler, which I caught on a clip.)
I use the Shelly sensor to send an emergency pushover notification with a camera group snapshot - showing the triggering event in all 3 cameras that cover the area.
Top
