Summary: I recovered a Night Owl DVR-BTD2-8-V2 that entered a boot loop after an apparently incomplete firmware update. The processor, RAM, NAND, Ethernet, HDMI, and U-Boot were still operational, but the ROMFS SquashFS partition was truncated.
After making complete NAND backups, I restored only the damaged ROMFS partition using a verified official firmware image. The DVR subsequently booted normally, connected to the network, completed an online firmware update, and returned to normal operation.
Device Information
| Component | Identification |
| Model | Night Owl DVR-BTD2-8-V2 |
| Mainboard | AHB8008RA-NB-N68C-OWL V1.01, dated 20200629 |
| SoC | Novatek NA51068 |
| Memory | 512 MiB DRAM |
| NAND | Winbond W25N01GV, 128 MiB SPI NAND |
| Original firmware found in flash | 1.4.0 |
| Final firmware after recovery | DVR-BTD2-8-V2_1.5.7 |
Mainboard AHB8008RA-NB-N68C-OWL V1.01, showing the CN1 UART header, NAND, HDMI, SATA connector, and video-decoder hardware.Original Symptoms
The DVR had worked recently and had performed firmware updates, but afterward it would no longer operate normally.
- No Night Owl interface
- No usable HDMI output
- No DHCP lease or visible network client
- Ethernet PHY lights remained active
- Blue Bluetooth indicator remained illuminated
- Removing the HDD made no difference
- Two known-good official 12 V power adapters made no difference
- CMOS battery removal and normal power resets did not help
From the outside, the DVR looked like it had suffered a failed mainboard, SoC, or other major hardware failure.
UART Connection
The board has a three-pin UART header marked CN1:
CN1 UART header used for recovery. The board labels RX, TX, and GND directly beside the header.
- RX — Receive
- TX — Transmit
- GND — Ground
I used a CP2102 USB-to-TTL adapter.
Serial Settings
| Baud rate | 115200 |
| Data bits | 8 |
| Parity | None |
| Stop bits | 1 |
| Flow control | None |
Wiring
| CP2102 Adapter | DVR CN1 Header |
| TXD | RX |
| RXD | TX |
| GND | GND |
| VCC / Red wire | Do not connect |
Important: Do not connect adapter VCC.
The red wire on my adapter supplied 5 V and remained taped off. Only TX, RX, and GND were connected.
The U-Boot autoboot delay was zero seconds, but sending Ctrl+C through the UART console could still interrupt boot.
What the UART Log Revealed
The board was not dead. U-Boot successfully initialized:
- CPU
- 512 MiB DRAM
- SPI NAND
- USB
- Ethernet
- HDMI
- Boot-logo partition
The failure occurred when U-Boot attempted to extract
boot/uImage from the ROMFS SquashFS partition.The repeated errors included:
Code:
Input is not in the XZ format (wrong magic bytes)
xz uncompress failed with error code 5
read_block: failed to read block
prefetch abort
data abort
The DVR would then reset and repeat the process.
The damaged ROMFS partition produced the same CRC32 every time:
52dcfded.That showed the failure was deterministic rather than random UART noise, unstable RAM, or an intermittent NAND read.
Root Cause
Offline examination showed that the ROMFS SquashFS filesystem was incomplete.
The meaningful programmed data stopped at a NAND-page boundary, leaving approximately 130 KB of required filesystem metadata missing.
The missing portion included critical:
- Inode tables
- Directory tables
- Fragment tables
- Lookup tables
- ID tables
The embedded Linux kernel itself was still valid:
| Image | Linux-4.9.118 |
| Payload size | 2,572,896 bytes |
| Load address | 0x00008000 |
| Entry point | 0x00008000 |
Both the U-Boot image-header CRC and kernel payload CRC were valid.
The evidence strongly suggested that an interrupted or incomplete firmware update had left the ROMFS partition truncated.
Code:
0x0000000 loader
0x0040000 fdt
0x0080000 fdt.restore
0x00C0000 boot
0x02C0000 env
0x0340000 priv
0x03A0000 rsvd
0x0400000 logo
0x0500000 romfs, size 0xA00000
0x0F00000 usr
0x4000000 work
0x7800000 mtd
The failure was isolated to the ROMFS partition beginning at
0x500000.Backups Made Before Repair
Before writing anything, I created and verified:
- A complete 128 MiB logical NAND backup
- A complete raw NAND backup including OOB data
- A separate backup of the damaged ROMFS partition
- SHA-256 hashes for the backup files
This was important because the NAND contains device-specific information, including:
- Serial information
- TUTK/cloud identifiers
- Private configuration
- Network identity
- Vendor-specific partitions
No bad NAND blocks were reported.
I will not publish the full NAND dumps because they contain private device identifiers and cloud credentials.
Verified Recovery Image
I obtained the correct official firmware package for the BTD2 hardware family and verified that it matched the device.
| Hardware family | AHB80N08R-LME-ND |
| Flash ID | EF AA 21 |
| Image filename | romfs-x.squashfs.img |
| File size | 3,448,896 bytes |
| Full-image CRC32 | ee7904ce |
| ROMFS payload CRC32 | 0981230b |
The file contained:
- A 64-byte firmware/update header
- A
0x34A000-byte ROMFS payload
USB and RAM Verification
The image was placed on a FAT32 USB drive and loaded into RAM:
Code:
fatload usb 0:1 0x02000000 romfs-x.squashfs.img
The complete file was verified:
Code:
crc32 0x02000000 0x34A040
Expected CRC32:
ee7904ceBecause the actual ROMFS payload begins 64 bytes into the file, I also verified:
Code:
crc32 0x02000040 0x34A000
Expected CRC32:
0981230bImportant flwrite Note
The U-Boot environment contained update aliases that referenced
flwrite, but running flwrite by itself did not process the image already loaded at 0x02000000.It returned:
Code:
PACK_ID error
DestAddr invalid
No NAND erase or write occurred.
I verified afterward that:
- The RAM image CRC was unchanged
- The original damaged ROMFS CRC was unchanged
Do not assume that standalone
flwrite will automatically process an image already loaded into RAM on this U-Boot build.Targeted ROMFS Repair
WARNING:
The following offsets and lengths applied to this exact DVR model, board revision, flash layout, and verified firmware image.
Using these commands on another model, hardware revision, or unverified image could permanently destroy the device.
Make complete NAND backups before writing anything.
I first verified the source payload CRC one final time:
Code:
Expected CRC32:
0981230bI then erased only the damaged ROMFS partition:
Code:
nand erase 0x500000 0xA00000
The 64-byte firmware header was skipped, and only the verified ROMFS payload was written:
Code:
nand write 0x02000040 0x500000 0x34A000
The write completed successfully:
Code:
3448832 bytes written: OK
The written data was then read back and verified:
Code:
nand read 0x04000000 0x500000 0x34A000
crc32 0x04000000 0x34A000
Readback CRC32:
0981230bThe readback CRC exactly matched the verified source payload.
First Boot After Repair
The repaired ROMFS was read successfully, and U-Boot found and extracted
boot/uImage:
Code:
### get_squashfs_file OK
loaded 2572960 bytes to 0x1D600000
The kernel passed validation:
Code:
Image Name: Linux-4.9.118
Verifying Checksum ... OK
Loading Kernel Image ... OK
Linux then started:
Code:
abce
UART output stopped after
abce, but HDMI came up and the normal Night Owl camera grid appeared.Final Result
The DVR successfully completed:
- Manual boot after the repair
- Complete cold boot
- HDMI initialization
- Linux startup
- Ethernet initialization
- DHCP and network connectivity
- Automatic online firmware update
- Automatic reboot after the firmware update
Final reported information:
| Model | DVR-BTD2-8-V2 |
| Firmware | DVR-BTD2-8-V2_1.5.7 |
| Firmware status | Up to date |
The normal camera grid returned after the firmware update, and Ethernet showed a solid link light with active traffic.
Conclusion
This unit did not have a failed CPU, RAM, HDMI circuit, Ethernet interface, or completely failed NAND chip.
The problem was an incomplete ROMFS SquashFS partition, most likely caused by an interrupted or failed firmware update.
The DVR was recovered by:
- Accessing U-Boot through UART
- Backing up the complete NAND before writing
- Preserving all device-specific partitions
- Verifying the correct official firmware image
- Skipping the firmware-update header
- Rewriting only the damaged ROMFS partition
- Verifying the write by CRC before rebooting
The DVR was restored without erasing its identity, cloud credentials, private configuration, or other working partitions.
Files Retained Privately
NAND128.BINNAND128-RAW.BINROMFS.BINSHA256-HASHES.txt- Original official firmware package
- Extracted verified ROMFS image
I will not post device-specific NAND dumps because they contain private identifiers and cloud credentials.
I would be interested to hear from anyone with the same board revision, or another BTD2 model, that has experienced the same firmware-update boot loop.
