You can probably avoid all that just by using a test clip in-situ.Not much luck last night dumping the flash due to it being soldered on the board and causing shorts. So will de-solder today and then try again.
#!/bin/sh
# This script holds the steps to unpack the flash dump from the raysharp-PowerEdge-R720.
# The offsets will very likely be specific to that version of firmware. There is no attempt to
# use logic to make it universal - it's as much a memory-jogger as anything.
# The assumption is the the flash dump follows this partition scheme from the serial console
# Kernel command line: mem=205M console=ttyAMA0,115200 root=/dev/mtdblock2
# rootfstype=squashfs mtdparts=hi_sfc:448K(boot),2560K(kernel),3M(rootfs),5824K(app),4032K(www),384K(para),64K(p2p)
# So the partitions are also deduced as follows:
#SPI Nor(cs 0) ID: 0xc2 0x20 0x18
#Block:64KB Chip:16MB Name:"MX25L128XX"
#SPI Nor total size: 16MB
#7 cmdlinepart partitions found on MTD device hi_sfc
#Creating 7 MTD partitions on "hi_sfc":
#0x000000000000-0x000000070000 : "boot"
#0x000000070000-0x0000002f0000 : "kernel"
#0x0000002f0000-0x0000005f0000 : "rootfs"
#0x0000005f0000-0x000000ba0000 : "app"
#0x000000ba0000-0x000000f90000 : "www"
#0x000000f90000-0x000000ff0000 : "para"
#0x000000ff0000-0x000001000000 : "p2p"
dd if=FlashDumpRedlineFirmware-D1.BIN of=boot.part bs=1 count=448K
dd if=FlashDumpRedlineFirmware-D1.BIN of=kernel.part bs=1 count=2560K skip=$((0x70000))
dd if=FlashDumpRedlineFirmware-D1.BIN of=rootfs.part bs=1 count=3M skip=$((0x2f0000))
dd if=FlashDumpRedlineFirmware-D1.BIN of=app.part bs=1 count=5824K skip=$((0x5f0000))
dd if=FlashDumpRedlineFirmware-D1.BIN of=www.part bs=1 count=4932K skip=$((0xba0000))
dd if=FlashDumpRedlineFirmware-D1.BIN of=para.part bs=1 count=384K skip=$((0xf90000))
dd if=FlashDumpRedlineFirmware-D1.BIN of=p2p.part bs=1 count=64K skip=$((0xff0000))
# The rootfs and app and www partitions are squashfs so can be extracted
[ -d rootfs.part_contents ] && sudo chmod -R 777 rootfs.part_contents/ && rm -rf rootfs.part_contents
sudo unsquashfs -d rootfs.part_contents rootfs.part
[ -d app.part_contents ] && sudo chmod -R 777 app.part_contents/ && rm -rf app.part_contents
sudo unsquashfs -d app.part_contents app.part
[ -d www.part_contents ] && sudo chmod -R 777 www.part_contents/ && rm -rf www.part_contents
sudo unsquashfs -d www.part_contents www.part
# I'm not sure if this method works correctly - the first time it yielded no results.
# The 'jefferson' tool worked OK.
# sudo modprobe mtdram total_size=32768
# sudo modprobe mtdblock
# sudo chmod 777 /dev/mtdblock0
# sudo cat mtd.part > /dev/mtdblock0
# sudo mount -t jffs2 /dev/mtdblock0 ~/tmp
#jefferson -d mtd.part_contents mtd.part
# mkfs.jffs2 -o mtd_new.part -d build_from_here
Agreed, it's a really useful tool, but I treat it as an indicator of content as it does tend to have a lot of false hits.Thanks for the script. I generally use: $> binwalk -e <firmware.bin> and it will auto extract everything.
That's ambitious!At this stage I will likely build Linux for the board using: hi35xx/hi35xx-buildroot
Will then take the raysharp_dvr binary found in the firmware binary and try and run that.
strings -8 raysharp.dvr yields some useful info :I am quite interested in what library/toolset was used to build the raysharp_dvr binary. Any thoughts?
compiler: arm-hisiv300-linux-gcc -DDSO_DLFCN -DHAVE_DLFCN_H -DNDEBUG -DOPENSSL_THREADS -DOPENSSL_NO_DYNAMIC_ENGINE -DOPENSSL_PIC -DOPENSSLDIR="\"/usr/local/ssl\"" -DENGINESDIR="\"/usr/local/lib/engines-1.1\"" -mcpu=cortex-a7 -mfloat-abi=softfp -mfpu=neon-vfpv4 -mno-unaligned-access -fno-aggressive-loop-optimizations -g
OpenSSL 1.1.0i-dev xx XXX xxxx
built on: reproducible build, date unspecified
platform: linux-generic32
OPENSSLDIR: "/usr/local/ssl"
ENGINESDIR: "/usr/local/lib/engines-1.1"
Dynamic section at offset 0xc17e90 contains 35 entries:
Tag Type Name/Value
0x00000001 (NEEDED) Shared library: [libpthread.so.0]
0x00000001 (NEEDED) Shared library: [libcrypt.so.0]
0x00000001 (NEEDED) Shared library: [libdevhal.so]
0x00000001 (NEEDED) Shared library: [libfreetype.so]
0x00000001 (NEEDED) Shared library: [librstool.so]
0x00000001 (NEEDED) Shared library: [libdl.so.0]
0x00000001 (NEEDED) Shared library: [librt.so.0]
0x00000001 (NEEDED) Shared library: [libstdc++.so.6]
0x00000001 (NEEDED) Shared library: [libm.so.0]
0x00000001 (NEEDED) Shared library: [libgcc_s.so.1]
0x00000001 (NEEDED) Shared library: [libc.so.0]
0x00000001 (NEEDED) Shared library: [ld-uClibc.so.0]
0x0000000c (INIT) 0x17b98
0x0000000d (FINI) 0xa4e6f4
0x00000019 (INIT_ARRAY) 0xc165e4
0x0000001b (INIT_ARRAYSZ) 832 (bytes)
0x0000001a (FINI_ARRAY) 0xc16924
0x0000001c (FINI_ARRAYSZ) 12 (bytes)
0x00000004 (HASH) 0x8128
0x00000005 (STRTAB) 0xf560
0x00000006 (SYMTAB) 0xa550
0x0000000a (STRSZ) 25660 (bytes)
0x0000000b (SYMENT) 16 (bytes)
0x00000015 (DEBUG) 0x0
0x00000003 (PLTGOT) 0xc27fd0
0x00000002 (PLTRELSZ) 5408 (bytes)
0x00000014 (PLTREL) REL
0x00000017 (JMPREL) 0x16678
0x00000011 (REL) 0x16440
0x00000012 (RELSZ) 568 (bytes)
0x00000013 (RELENT) 8 (bytes)
0x6ffffffe (VERNEED) 0x163a0
0x6fffffff (VERNEEDNUM) 2
0x6ffffff0 (VERSYM) 0x1599c
0x00000000 (NULL) 0x0
root:Al19!@:0:0::/root:/bin/sh
Here you go, probably :this looks pretty interesting too me, have to figure how its able to be called now.
#!/bin/sh
#load the phy module
# insmod /hitoe/stmmac.ko
. /etc/profile
echo 4096 > /proc/sys/vm/min_free_kbytes
echo 10 > /proc/sys/vm/dirty_background_ratio
echo 20 > /proc/sys/vm/dirty_ratio
echo 200 > /proc/sys/vm/vfs_cache_pressure
echo "rootfs compile user:tuzuguo time:2019-04-28 14:57:50"
ifconfig lo 127.0.0.1
ifconfig eth0 192.168.1.99
# mount -t nfs -o nolock 192.168.1.63:/home/admin1/work/hi/3531/nfs /home/
telnetd &
cd /moudle/ko_hi3521a/
insmod extdrv/rs_gpio.ko
./load3521a -i
readkeyid
keyid=$?
if [ $keyid = "1" ];then
insmod extdrv/keygpio.ko
echo "The KEY_ID is key_gpio!"
elif [ $keyid = "3" ] || [ $keyid = "4" ];then
insmod extdrv/keytouch.ko
echo "The KEY_ID is key_touch!"
elif [ $keyid = "2" ];then
echo "The KEY_ID is key_serial!"
else
echo "The KEY_ID is error!"
fi
insmod extdrv/gpioi2c.ko
#insmod extdrv/rtc_ds1339.ko
insmod extdrv/hi_ir.ko
insmod extdrv/hi_wdt.ko
insmod extdrv/hi_rtc.ko
#insmod extdrv/rtc_rx8010.ko
insmod extdrv/74hc165.ko
checkADauthor
ADauthor=$?
if [ $ADauthor = "2" ];then
insmod extdrv/pr1000_drv.ko
else
readkeyboardid
board_id=$?
norm
if [ "$?" = "1" ];then
insmod extdrv/RSAD_DRV.ko vdec_mode=0 boardid=$board_id
echo "Set RSAD_DRV NTSC!"
else
insmod extdrv/RSAD_DRV.ko vdec_mode=1 boardid=$board_id
echo "Set RSAD_DRV PAL!"
fi
fi
readkeyboardid
board=$?
if [ $board = "106" ];then
insmod extdrv/DriverEs8323.ko
fi
#checkkey
#ext4 fs check
index=1
for i in a b c d e f g h
do
disk=/dev/sd$i$index
if [ -b $disk ]; then
checke2 $disk
e2type=$?
if [ $e2type = "0" ]; then
echo "e2fsck $disk ..."
fsck.ext2 -y -v $disk
else
echo "$disk not ext, and don't need fsck"
fi
else
echo "$disk not exist"
fi
done
mount -t tmpfs -o size=100K tmpfs /var/run
mount -t tmpfs -o size=100K tmpfs /var/lock
mount -t tmpfs -o size=100K tmpfs /var/log
mount -t tmpfs -o size=100K tmpfs /var/tmp
mount -t tmpfs -o size=4K tmpfs /keys
mount -t tmpfs -o size=64k tmpfs /tmp
mount -t tmpfs -o size=100K tmpfs /etc/ppp
mount -t tmpfs -o size=200K tmpfs /P2P
mount -t tmpfs -o size=10K tmpfs /etc/Wireless/RT2870STA
mount -t tmpfs -o size=64k tmpfs /usr/share/udhcpc
mount -t squashfs /dev/mtdblock5 /agent
mount -t squashfs /dev/mtdblock3 /mnt
cp /ppp/* /etc/ppp -rf
cp /usr/udhcpc/* /usr/share/udhcpc -rf
rsSystemServer &
cp /root/passwd /etc/ppp/passwd
cp /root/passwd- /etc/ppp/passwd-
cp /etc/Wireless/MT7601USTA.dat /etc/Wireless/RT2870STA/
cp /etc/Wireless/RT2870STA.dat /etc/Wireless/RT2870STA/
SerialSwitch
echo "open Serial!"
else
himm 0x12080030 0xd01
echo "close Serial!"
fi
himm 0x120f00c4 0x02
cd /mnt
./raysharp_dvr &
mount -t squashfs /dev/mtdblock4 /plugs
boa &
Impressive!I’ve also rebuilt the u-boot bootloader from the hi3521 sdk that has the u-boot env enabled instead of locked
I've just thrown up a post asking for help with a few things (DVR4-1580/DVR4-720P/DVR-6904AU) and this is one part I need help with, see here.Alternate DVR8-4575 Codes
Code:DM-274 DM-284 DM-298 DM-299 DM-307 DM-319 DM-321 DM-327 DM-358 DM-359 DVR16-4575 DVR16-4780 DVR4-1590 DVR4-1600 DVR4-4480 DVR4-4575 DVR4-4780 DVR8-1590 DVR8-1600 DVR8-4480 DVR8-4575 DVR8-4780 RS-DM-284 RS-DM-299 RS-DM-307
