R0 / DS-2CD2x32 BrickfixV2 brick recovery and full upgrade tool - enhanced.
I think they're CN models... bought from AliExpress
So the CN brickfix firmware is required..?
Hi..the big tftp upload today was unfortunately a no go
there was just one line on the console '...192.0.0.128...initialised' and nothing further.
Had granted firewall permissions.
Plugged camera back into the switch (it has a static ip of 192.168.1.121) and all was well, except no picture.
should the IP on the camera be set to DHCP..?
it is a CCCH serial number BTW
thanks
edit - they are just connected directly ie LAN port of camera to LAN port of PC...should I be going through a router...or crossover cable...?
Reactions: Schardt
For the tftp updater activity?
A direct connection between the camera and PC can get in the way of the tftp updater handshake succeeding.
Both sides need extra time for the link detect operation to complete.
The same comment applies if camera power is via PoE - best to power with external 12v.
Connecting both the PC and camera each direct to router or switch ports should work OK.
Reactions: michaelsandy
Hello,
Just wanted to say a huge thanks to alastairstevenson for his great tutorial to upgrade R0 camera.
I followed every steps and it worked like a charm (I use a switch and it worked perfectly).
Just 2 points to save time to others:
  • I loose time because of windows: the camera would not find the TFTP server even if I authorized access. Reason: TFTP relies on UDP protocol and by default it's the TCP protocol that's enabled . Solution: in windows firewall and change TCP to UDP for the TFTP application and the camera will find the TFTP server
  • I had to apply versions in sequence (5.1.x -> 5.2.0 -> 5.3.0 -> ....). Skipping versions didn't work well.
Reactions: alastairstevenson
ok, thanks for the tcp/udp advice Bob, and I already gave a thumbs up to Alistair
I thought you could just go with IPC_R0_EN_STD_5.4.5_170401-digicap.dav...where are the other versions?
msandy
Hi, unfortunately unsuccessful with both a 2532 and a 2132 camera.
At least I could not see either of the cameras using the SADP tool ...am on a 192.168.1.x network
They weren't visible in the router, either.
Tried fixing the 2532 after the 2132. being particularly careful at the checksum stage
Software wrote successfully as attached.
Should I just start again?
Michael Sandy
That would be worth trying.
I checked your transcript, it's normal, no errors.
And I checked your modded mtd6 - your changes are all correct.
On the face of it, the fixup should have just worked, there is no obvious problem.
What version of firmware did you use for Stage3 of the brickfix procedure?
Generally the 5.4.5 works well at that point.
Thanks Alastair, it was 5.4.5, build 170401.
And that should configure as DHCP by default..?
Edit- UPDATE****
Downloaded a new version of SADP and can see the 2 udpated
and one original cameras
Not actually sure what to do now, but the surgery seems to
have been a success.
Thanks again Alastair and others!
No - found devices 002 and 003 are showing 'min-system' with firmware version 4.0.8.
That's a recovery mode that's entered when a camera cannot boot properly.
It's also the state that would show when the brickfixV2 firmware is initially installed as it uses a modded version of the recovery mode.
Hi all ...
I recently retired with IT background and started playing with IP camera's ... something new to learn
As a side job, I clear out closed offices of all IT equipment and get to keep the hardware as payment .... got some nice Cisco POE switches and AV equipment ... also picked up a DS-7604NI-E1 DVR and (4) DS-2CD2132.
Since the original company will not provide passwords for any of the IT hardware, I basically reset everything back to factory and go from there ...
I first tested the camera(s) which had fixed IP's ... so without reading anything, found the reset button inside and reset back to default ... easy stuff. BUT not finding a reset on the DVR forced me to start reading ...
Found a hit on Google using brickfixv2 for DVR's and ultimately to this forum ... lots of good info :)
I went through the procedure on one of my cameras even though I had access just to test, everything worked perfectly as documented ...
BUT, this is where I'm stuck. The instructions appear to target camera's specifically, the only reference to DVR is in the instructions :
How To Upgrade >>> 6. Power off and power on the DVR/DVS/IPC. The device will search the new firmware and upgrade it automatically.
I'm also not clear on which firmware to DL as I'm still trying to figure out the Series values for HIK equipment on the Europe server
Can someone clarify if the brickfixv2 works on DVR's as it does on camera's or is there a different method to recover access ?
Cheers B
No, this language change / recovery method is only for Hikvision R0 series cameras.
There are various methods to regain access to this device.
First - use SADP to find the device and determine the firmware version.
If the firmware is old enough, there is a reset tool that might work.
Probably the easiest method is to re-apply the same version of firmware as is currently installed by using Hikvision's tftp updater method.
The firmware is small enough that there isn't a need to use the Scott Lamb tftp updater clone - Hikvision's original will work OK.
Tool and instructions here :
Firmware here :
And if you want a bit of fun, and the cameras have firmware of 5.4.0 or older, there is the 'trojan horse method', example here :
Firmware here :
First, TY for your reply
As per SADP, this DS-7604NI-E1 has firmware V3.4.5 build 170224 which I cannot locate on any DL sites and there is a static IP set on the unit which would have accessed a specific Vlan associated with the video security network
I tried the direct TFTP load method (192.0.0.128) using a few different firmware versions, the TFTP server always shows > Connect client failure,0
* all the cameras that were attached to this DVR were reset and firmware updated as standalone units
Is there any hope to gain reset to this unit ?
Cheers B
Cheers B
Just pick the nearest one - doesn't have to be exact.
The tftp updater can be a little fussy about the environment.
It works best when both PC and NVR are each connected to their own switch or router port, as opposed to being connected directly.
Did the initial execution of tftpserve.exe generate a Windows firewall popup, with OK clicked to allow access?
In any case, temporarily disable Windows firewall to allow inbound access.
What is the IP address?
Purchased a TTL serial and loaded firmware as per guides .... I'm able to access the NVR now
Thank you to everyone who replied, good and informational support
Now to learn all about Hikvision and all its quirks
