file: http://download.hikvision.com/UploadFile/Soft/NVR/NVR_(78_71_4_8路_SN)_V3.0.21_170417.zip
(DS-7100/7800N-SN(4、8路)系列支持萤石云程序包 - V3.0.21 build170417)
it's working ! just change the language flag ;-)
just curious - was this the result of something that was specifically done to it, or just a random event?Now, I can start troubleshooting on HIK camera which seems dead.
That's usually a troublesome method - best to connect as normal to a switch or router.I am trying to connect directly with the laptop.
If you don't have SADP, worth installing.but I cannot find it when connecting to it;
It will find the camera whatver IP address it's using, or if it's in 'min-system' mode. Hangzhou Hikvision Digital Technology Co. Ltd.
Seems when installing I didn't isolated correctly the connector and I found water on the ETH connectorCamera was powered thru a splitter, as the switch isn't POE.
Now, camera power-on (I see the LED from IR) but I cannot find it when connecting to it; I am trying to connect directly with the laptop.
hiktools05R1.exe lang digicapNVR_DS-7108N-SN_V3.0.21_170417.dav 1
resulted in:
Head raw data(108b) :
00000000 E9 9A F7 B6 54 AE DD D3 42 B8 A3 AB B5 CB B5 BE ....T...B.......
00000010 CF BC FE D6 E6 DD D3 BA 46 5C 54 40 34 4A 41 45 ........F\T@4JAE
00000020 43 01 29 35 22 2C 45 46 5C 54 40 34 B5 BE BA CD C.)5",EF\T@4....
00000030 FE D6 CA DD C6 B9 AC 83 AA BF CB B5 BE BA CD BC ................
00000040 BE A3 BE BC C8 DC 8D DF DE B9 9B D2 C0 A0 DD FE ................
00000050 CA DD D3 BA B9 A3 AB BF CB B5 BE BA CD BC FE D6 ................
00000060 25 D2 BA B9 D3 EE 91 CB 15 DA B0 DA
Head decoded data(108b) :
00000000 53 57 4B 48 82 64 00 00 F8 01 00 00 0A 00 00 00 SWKH.d..........
00000010 02 00 00 00 2C 00 00 00 FF FF FF FF FF FF FF FF ....,...........
00000020 FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 ................
00000030 00 00 00 00 15 03 15 20 01 00 00 00 00 00 00 00 ..... ........
00000040 68 69 63 6F 72 65 2E 74 61 72 2E 6C 7A 6D 61 00 hicore.tar.lzma.
00000050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000060 F8 01 00 00 70 45 2E 00 A0 64 0A 17
Magic number : 0x484B5753
iHeaderCheckSum : 0x00006482 [25730]
iHeadTotalLen : 0x000001F8 [504]
iFileNum : 0x0000000A [10]
iLanguage : 0x00000002 [2] CN
iDeviceClass : 0x0000002C
iOEMCode : 0xFFFFFFFF
iFirmwareVer : 0xFFFFFFFF
iFeature: 0xFFFFFFFF
Calculated CheckSum : 0x00006482 [25730]
Full decoded data (with full files block):
00000060 F8 01 00 00 70 45 2E 00 A0 64 0A 17 75 49 6D 61 ....pE...d.uIma
00000070 67 65 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ge..............
00000080 00 00 00 00 00 00 00 00 00 00 00 00 68 47 2E 00 ............hG..
00000090 F0 F7 16 00 99 0C 6C 0B 61 70 70 2E 74 61 72 2E .....l.app.tar.
000000A0 6C 7A 6D 61 00 00 00 00 00 00 00 00 00 00 00 00 lzma............
000000B0 00 00 00 00 00 00 00 00 58 3F 45 00 F0 F0 0D 00 ........X?E.....
000000C0 D3 62 F0 06 64 76 72 43 6D 64 2E 74 61 72 2E 67 .b..dvrCmd.tar.g
000000D0 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 z...............
000000E0 00 00 00 00 48 30 53 00 28 30 00 00 BE 01 18 00 ....H0S.(0.....
000000F0 76 65 72 73 69 6F 6E 63 74 72 2E 74 61 72 2E 6C versionctr.tar.l
00000100 7A 6D 61 00 00 00 00 00 00 00 00 00 00 00 00 00 zma.............
00000110 70 60 53 00 D0 25 01 00 15 30 92 00 68 69 73 69 p`S..%..0..hisi
00000120 2E 74 61 72 2E 6C 7A 6D 61 00 00 00 00 00 00 00 .tar.lzma.......
00000130 00 00 00 00 00 00 00 00 00 00 00 00 40 86 54 00 [email protected].
00000140 C0 9D 0C 00 BB 99 47 06 72 61 6D 64 69 73 6B 2E ......G.ramdisk.
00000150 67 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 gz..............
00000160 00 00 00 00 00 00 00 00 00 24 61 00 D8 A8 0A 00 .........$a.....
00000170 76 29 4F 05 77 65 62 73 2E 74 61 72 2E 6C 7A 6D v)O.webs.tar.lzm
00000180 61 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a...............
00000190 00 00 00 00 D8 CC 6B 00 60 48 09 00 39 2F 9F 04 ......k.`H..9/..
000001A0 73 74 61 72 74 2E 73 68 00 00 00 00 00 00 00 00 start.sh........
000001B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
000001C0 38 15 75 00 88 07 00 00 F8 C2 03 00 6E 65 77 5F 8u.........new_
000001D0 31 30 2E 62 69 6E 00 00 00 00 00 00 00 00 00 00 10.bin..........
000001E0 00 00 00 00 00 00 00 00 00 00 00 00 C0 1C 75 00 .............u.
000001F0 68 03 00 00 AC DA 01 00 Language changed to 1
hiktools05R1.exe digicapNVR_DS-7108N-SN_V3.0.18_151231.dav
results in:
HIK firmware header converter 0.5R
00000000 E9 9A F7 B6 D1 AD DD D3 42 B8 A3 AB B5 CB B5 BE ........B.......
00000040 A3 83 B0 B2 DD DC A3 AB BF CB B5 BE BA CD BC FE ................
00000060 25 D2 BA B9 53 5C A9 CB 2C B2 D6 C6
00000000 53 57 4B 48 07 67 00 00 F8 01 00 00 0A 00 00 00 SWKH.g..........
00000040 75 49 6D 61 67 65 00 00 00 00 00 00 00 00 00 00 uImage..........
00000060 F8 01 00 00 F0 F7 16 00 99 0C 6C 0B
iHeaderCheckSum : 0x00006707 [26375]
Calculated CheckSum : 0x00006707 [26375]
00000060 F8 01 00 00 F0 F7 16 00 99 0C 6C 0B 61 70 70 2E .........l.app.
00000070 74 61 72 2E 6C 7A 6D 61 00 00 00 00 00 00 00 00 tar.lzma........
00000080 00 00 00 00 00 00 00 00 00 00 00 00 E8 F9 16 00 ...............
00000090 00 43 09 00 E5 DB 9B 04 64 76 72 43 6D 64 2E 74 .C......dvrCmd.t
000000A0 61 72 2E 67 7A 00 00 00 00 00 00 00 00 00 00 00 ar.gz...........
000000B0 00 00 00 00 00 00 00 00 E8 3C 20 00 28 30 00 00 .........< .(0..
000000C0 D9 1B 18 00 68 69 63 6F 72 65 2E 74 61 72 2E 6C ..hicore.tar.l
000000D0 7A 6D 61 00 00 00 00 00 00 00 00 00 00 00 00 00 zma.............
000000E0 00 00 00 00 10 6D 20 00 38 40 2E 00 CF 0D 0B 17 .....m .8@.....
000000F0 68 69 73 69 2E 74 61 72 2E 6C 7A 6D 61 00 00 00 hisi.tar.lzma...
00000100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000110 48 AD 4E 00 B0 9C 0C 00 32 A0 48 06 6E 65 77 5F H.N.....2.H.new_
00000120 31 30 2E 62 69 6E 00 00 00 00 00 00 00 00 00 00 10.bin..........
00000130 00 00 00 00 00 00 00 00 00 00 00 00 F8 49 5B 00 .............I[.
00000140 68 03 00 00 48 DC 01 00 72 61 6D 64 69 73 6B 2E h...H...ramdisk.
00000160 00 00 00 00 00 00 00 00 60 4D 5B 00 D8 A8 0A 00 ........`M[.....
00000170 76 29 4F 05 73 74 61 72 74 2E 73 68 00 00 00 00 v)O.start.sh....
00000180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000190 00 00 00 00 38 F6 65 00 F0 07 00 00 8B FA 03 00 ....8.e.........
000001A0 76 65 72 73 69 6F 6E 63 74 72 2E 74 61 72 2E 6C versionctr.tar.l
000001B0 7A 6D 61 00 00 00 00 00 00 00 00 00 00 00 00 00 zma.............
000001C0 28 FE 65 00 D8 25 01 00 FB 58 92 00 77 65 62 73 (.e..%...X..webs
000001D0 2E 74 61 72 2E 6C 7A 6D 61 00 00 00 00 00 00 00 .tar.lzma.......
000001E0 00 00 00 00 00 00 00 00 00 00 00 00 00 24 67 00 .............$g.
000001F0 20 B9 09 00 DC EF D7 04
Yes, that's correct.Im suspecting there is other parts of the firmware which need to be altered, not just the one language setting for the NVR to ignore the language mismatch.
version.region=overseas
version.major=3
version.minor=4
version.soft=90
firewareID=0000000100000001000002000000002a00000001000000020003
base.buildtime=161008
last.buildtime=161008
openssl.version=v1
version.region=overseas_ml
version.major=3
version.minor=4
version.soft=90
firewareID=0000000100000001000002000000003d00000001000000020005
base.buildtime=160926
last.buildtime=160926
openssl.version=v1
When changing the language in the firmware header, you are mainly affecting one of the file verification checks that's done prior to the upgrade process taking place.
The firmware internally has a multiplicity of version labels that are checked against the NVR hardware signature block to see what's been decided as allowed combinations.
./hikpack -t k41 -x digicap.davDS-7108N-SN_V3.0.18_build151231 -o contents_nvr_3.0.18/
Magic : 484b5753
hdr_crc : 00006707 (OK)
lang_id : 00000002
date_hex: 20150315
devclass: 0000002c
File: uImage, CRC OK
File: app.tar.lzma, CRC OK
File: dvrCmd.tar.gz, CRC OK
File: hicore.tar.lzma, CRC OK
File: hisi.tar.lzma, CRC OK
File: new_10.bin, CRC OK
File: ramdisk.gz, CRC OK
File: start.sh, CRC OK
File: versionctr.tar.lzma, CRC OK
File: webs.tar.lzma, CRC OK
=== Tail record:
File: new_20.bin, CRC OK
./hikpack -t k41 -x digicap.davDS-7108N-SN_V3.0.21_build170417 -o contents_nvr_3.0.21
Magic : 484b5753
hdr_crc : 00006482 (OK)
lang_id : 00000002
date_hex: 20150315
devclass: 0000002c
=== Tail record:
No, those files were from NVR firmware. Check out the 3.4.90 version numbers - 76/77/78 series.Im guessing those version numbers are from camera firmware rather than NVR's.. am i right?
With the exception of uImage, they are all encrypted, using the 'ded' program.All the files outputted seem to be corrupted.
alastair@PC-I5 ~/cctv/NVRFirmware/3.0.21 $ ll
total 15008
drwxr-xr-x 2 alastair alastair 4096 Sep 28 18:21 ./
drwxrwxr-x 30 alastair alastair 4096 Sep 28 17:55 ../
-rw-r--r-- 1 alastair alastair 7676924 Apr 17 04:04 digicap.dav
-rw-r--r-- 1 alastair alastair 7674623 Sep 28 18:07 NVR_(78_71_4_8路_SN)_V3.0.21_170417.zip
alastair@PC-I5 ~/cctv/NVRFirmware/3.0.21 $ hikpack_2.5 -t k41 -x digicap.dav -o contents
Magic : 484b5753
lang_id : 00000002
date_hex: 20150315
devclass: 0000002c
=== Tail record:
alastair@PC-I5 ~/cctv/NVRFirmware/3.0.21 $ cp contents/versionctr.tar.lzma .
alastair@PC-I5 ~/cctv/NVRFirmware/3.0.21 $ hikpack_2.5 -t k41 -d versionctr.tar.lzma -o dec_versionctr.tar.lzma
alastair@PC-I5 ~/cctv/NVRFirmware/3.0.21 $ unlzma --single-stream dec_versionctr.tar.lzma
alastair@PC-I5 ~/cctv/NVRFirmware/3.0.21 $ tar -xvf dec_versionctr.tar
hiklogo
nolink
noresource
showlogo
sysVersion.bin
vca_encrypt_3520D.ko
alastair@PC-I5 ~/cctv/NVRFirmware/3.0.21 $ cat sysVersion.bin
standardalastair@PC-I5 ~/cctv/NVRFirmware/3.0.21 $
