Greeting IP Cam Experts,
Newbie here and I am looking to install an indoor PoE backup camera system to protect against potential Wi-Fi jamming and would appreciate your recommendations for the best setup.
Setup Details:
- Coverage Area: Room A (24' W x 30' L, with front and back access doors) and Room B (11.8' W x 11.9' L, connected via a side door on the right of Room A).
- Lighting: Well-lit from dusk to dawn.
- Budget: Around $500.
- Equipment Under Consideration:
- Reolink NVR RLN8-410 (No HDD) - $152
- Reolink FE-P (for Room A) - $136
- Reolink RLC-820A (for Room B) - $80
- Optional: Reolink OMVI 3i ($230) for Room A if the fisheye camera view quality is poor due to distortion.
(Note: All cameras have a MicroSD slot, fit within my budget, and per the manufacturer, do not use Dahua, Hikvision or Huawei/HiSilicon components.)
Questions:
1. Can these cameras continuously or loop-record to both a MicroSD card and the NVR simultaneously?
2. Can flat, oxygen-free copper Cat 6/6e Ethernet cables be used instead of standard round cables?
3. Will this configuration work properly within a VLAN setup?
Thanks in advance for your time and help!
Setup Details:
Questions:
