PTZ4E25X-T180 Review
Arjun
10,293
13,445
USA
Any reviews on the PTZ4E25X-T180 Review?
With both sensors way too small, I would guess it will be like many such cameras:
Great for overview and maybe tracking in bright daytime sunlight, and basically suck at night/low light. Though if you're willing to run the white light illuminators all night it would likely improve the image out to 60-80ft
Reactions: JDreaming and Arjun
This is probably a good option for those that don't want to route multiple ethernet cables to one spot
Good question, I'm guessing 2. The Overview one and the PTZ another
For what 2 IPs?
Even if camera have 2 separate SOC's (processors) for each channel due power processing reasons (like in Hubble series), it simply works as one camera with one IP and 2 channels (like in thermal cams)...
IVS in linkage mode is shared, PTZ reacts at objects detected by panorama...
Of course, I knew that! :facepalm: Thats how my thermal worked.
I was thinking channels. But I suppose it has 3 channels?
No two.. panorama (single channel like in normal 5849-A180) and PTZ...
panorama channel have also that strange Dahua specific 180 degree resolution / ratio and with horizontal compression...
the only sign that it have 2 separate SOCs / processors are separate RAM/ROM sizes for each channel.
Any idea if the fixed cameras on top are varifocal?
Another question, is the position of the 180 degree camera on top adjustable?
Thanks, how would you go about adjusting the position of the PTZ then (hardware wise)? Would it just mount the same way a PTZ would and then I would manually set the home position in the web interface?
Also, can this unit work in both Independent and Linkage mode?
Is there a model like this with a better sensor? I really like the 1 camera option but would like 1/8 or better if possible. If not can this model be setup with just a SD Card with alerts coming to phone?
