PTZ fails after firmware update
Please help with the firmware for the ZY-PEZ40-SNY camera after the update, PTZ ZOOM control disappeared Avtofocus , version V5.00.R02.000589C9.10010.040200.0020000 platform HI3516EV300S38H50AI Thanks in advance!Screenshot_2021-07-30-19-36-45-790_com.xm.csee.jpgthe seller gives the firmware link but the firmware is not installed XMEye Wired PTZ firmware (ZY-PEZ40-SNY) - Google Drive
Your advice did not help, still is a red image.
Try from post 251;
I noticed in light areas it had colour, I went into the Web interface again and selected B&W for Day Night mode, This was on Star IR. it switched the camera into B&W and fixed the issue which I believe is simply due to the IR lights giving off a strong Red glow and the image sensor still looking for full colour. I will run it again tonight to test again but hopefully this has fixed both issues,
Hello, friends. The problem is like many, after updating the firmware does not work PTZ, zoom, focus. Salesman does not answer.
Camera XM530_85X50_8M firmware V5.00.R02.0003068d
firmware through CMS and reset do not help
Hello! I bought a video surveillance camera on Aliexpress. After updating the firmware, the camera stopped working in zoom mode, and the image clarity is not adjusted. Device version: XM530_R80x50-PQ_8M; Software version: v5. 00. R02. 00030737.10010.349f17. 0000000; firmware release date - 2021.06.08.Aliexpress seller ignores requests.
Привет! Я купил камеру видеонаблюдения на Aliexpress. После обновления прошивки камера перестала работать в режиме масштабирования, а четкость изображения не регулировалась. Версия устройства: XM530_R80x50-PQ_8M; Версия программного обеспечения: v5. 00. R02. 00030737.10010.349f17. 0000000; дата выхода прошивки - 2021.06.08.Продавец Aliexpress игнорирует запросы.
Привет!пробуй мне прислал продавец камераScreenshot_2021-08-12-18-51-19-337_com.alibaba.aliexpresshd.jpg
Reactions: Trustnoone161
Hello All,
I managed to get firmware for my camera and the PTZ function now works. File is attached.
Ich habe es geschafft, Firmware für meine Kamera zu bekommen und die PTZ-Funktion funktioniert jetzt. Datei ist angehängt.
John
Dear John good evening
This firmware upgrade is for the camera NG4RT-53718-30X ?
If yes, how it is possible to upload the firmware upgrade to the camera NG4RT-53718-30X ?
Thank you
George
NSGood evening, please help. I am facing a problem with the processor overheating for my camera XM530_80x50_8M and the signal loss. It only works when I disconnect and then connect the power
Hello,
I have similar issue, did auto-update via xmeye app and now PTZ and focus doesn't work.
Current firmware version is: V5.00.R02.00030679.10010.349b00.0020010
I don't know which version was installed previously
Cam version: XM530_80x50_8M
Cam model: NZR10X-52710
I've contacted seller on aliexpress and he sent me firmware file, but I'm unable to flash it.
I've tried with VMS software from Polyvision - it just fails with unknown error.
Also tried with web interface, it doesn't give errors, but I can see "Upgrade [Exception]" in logs.
Is there anything I'm missing in order to get successful upgrade?
Maybe the file they sent is wrong, could you please help me to find the correct file?
Upgrade this firmware
Hi all,
I am also troubleshooting the PTZ error with my camera.
camera model: NZRX-207-6W
firmware: V5.00.R02.00030674.10010.344308.0000000
I've tried several firmwares but cannot get PTZ to work anymore.
I also tried the preset options but they did not help.
your support is highly appreciated.
thank you.
Reactions: resident
Hallo Oleglevsha
Hallo Tinbum
Kamera funktionier jetzt,habe es mit call 96 auf Werkseinslellung zurückgesetzt.
nochmal 1000 dank!!!!!!!!!. für eure Hilfe.
Hello Oleglevsha
Hello Tinbum
Camera now, i.e. with call 96, it has reset to work saturation.
another 1000 thanks!!!!!!!!!. for your help.
Dear Sir,
Can you post your ptz settings for this camera?
explain what you are specifically interested in
Hi oleglevsha,
Thank you for replying. I have this camera which was almost dead for 2 years due to covid and today i found your article and updated the software using one of the provided firmware here. now its back to life and ptz is working too but its too slow. how to increase decrease its speed. i am posting its version here.
Hi oleglevsha,
also would like to know if there's any acrylic cover for these ptz's
