PTZ controls suddenly stopped working
I can't locate a 'USERS' tab or similar.
I can find this
or this - which is the only place I can see that mentions ONVIF
Look under System > Account > ONVIF User tab
ETA: Never mind.. I see now you don't have that tab there. Looked at one of my older cams, it doesn't have the tab either. I guess maybe before there was a separate ONVIF user.
Reactions: JDreaming
Yep not there anymore
From the Find/Inspect screen that you posted, looks like BI shows HTTP errors 12030 and 12029 when trying to access the cam. I see some others with the same on a quick search but I don't see any clear resolution.
Yeah I've been searching for a solution in multiple places.......hopefully someone figures it out eventually. Thanks to you and the others in this thread for trying.
FWIW - I'm using Vivaldi browser and it works just fine with BI and UI3. And, knock on wood, I haven't had any further problems since starting this thread.
Oh, and Brave also works fine.
That is strange. Let's blame time change LOL
Ive been lurking here for about 3 years. Ive never had to make a post until now because I'm capable of searching past posts to find what I've needed. Every time there has been a problem I was able to search here and solve the issues. For that I am grateful to all of you for sharing your knowledge.
With that said I woke up this morning and for some reason the ptz controls for BI wouldn't work on my fairly new ptz425db-at. They worked fine yesterday. Thats when I started searching here for the solution and found this topic. I changed the setting to (dahua v4) as suggested on page 1 and now it works fine. Like user wittaj mentioned early on - I'm going to blame the time change since the time changed last night. Thanks again to everyone and thanks for hosting this site.
