geezernerd
- Aug 12, 2015
- 40
- 32
The group tab only contains thisTry the group tab
Yep not there anymoreLook under System > Account > ONVIF User tab
ETA: Never mind.. I see now you don't have that tab there. Looked at one of my older cams, it doesn't have the tab either. I guess maybe before there was a separate ONVIF user.
No change unfortunatelyTry just turning off ONVIF authentication in your second screen above.
The presets work fine when accessing the camera through the internet browser, however they still don't work in BI, along with the +- focus and arrows.Can you go to presets?
From the Find/Inspect screen that you posted, looks like BI shows HTTP errors 12030 and 12029 when trying to access the cam. I see some others with the same on a quick search but I don't see any clear resolution.
That is strange. Let's blame time change LOL
